Dotetcher Posted May 14, 2018 Share Posted May 14, 2018 (edited) The one on my 1997 has just rusted through at the base.Anything special I should be doing before trying to loosen the nuts. Is shearing the bolts off and issue? Alternate heating and penetrating oil or not necessary? I do NOT want to shear any of these bolts off. TIA Edited May 14, 2018 by Dotetcher Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted May 14, 2018 Share Posted May 14, 2018 It's most common for the nut to have more friction against the stud than the stud has against the head, so you just end up unscrewing the stud, which is a lot better than breaking one off. Soak them up good and let them set overnight. 1 Quote Link to comment Share on other sites More sharing options...
Dotetcher Posted May 14, 2018 Author Share Posted May 14, 2018 Thanks Joe Quote Link to comment Share on other sites More sharing options...
srideaux Posted May 14, 2018 Share Posted May 14, 2018 I have to agree with rockmeupto125 this is excellent input / advice. Quote Link to comment Share on other sites More sharing options...
dejah Posted May 16, 2018 Share Posted May 16, 2018 i have a header off a 98 cbr1100xx if u need 1 Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted May 16, 2018 Share Posted May 16, 2018 Dejah, where are you? I do not have a carbed header for him. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted May 17, 2018 Share Posted May 17, 2018 On 5/15/2018 at 10:22 PM, dejah said: i have a header off a 98 cbr1100xx if u need 1 . bump Quote Link to comment Share on other sites More sharing options...
dejah Posted May 17, 2018 Share Posted May 17, 2018 i'm in ohio Quote Link to comment Share on other sites More sharing options...
dejah Posted May 17, 2018 Share Posted May 17, 2018 dejahone1@aol.com Quote Link to comment Share on other sites More sharing options...
Dotetcher Posted May 20, 2018 Author Share Posted May 20, 2018 Thanks dejah. I missed this post. I found one from a 97 at a salvage yard in California. Should be here thisweek. Quote Link to comment Share on other sites More sharing options...
