Parting out '98 BlackBird
Basically it was stored outside in Florida sun for quite a long time, some parts have seen better days, some are mint/intact...Motor is trash, but there are few good things in it or on it...gauges are very good, full Yoshi pipe very nice (needs cleaning/polishing) very small dent underneath, on one of the header pipes, rotors, calipers, masters, clutch slave, plates w/pressure plate, starter, seat (needs new cover), subframe, shock, swingarm, harness etc....check photos, if you need photos/close ups or higher resolution - send me an e-mail or PM me...Plase dibs in this thread if interested. Number of my posts not saying much about me but if you would feel more comfortable dealing with me over e-bay - no problem, PayPal is cool, you pay actual shipping cost.
Updated list of parts available:
Yoshimura RS-3 full system $300
Gauges $200
Air-box with K&N filter $25
Front rotors (12xxx miles) $100
Front axle $20
Right rear set (rear brake lever, bracket, peg, master w/res.) $35
Swingarm w/pivot bolt $40
Passenger brackets (both, right side have peg) $30
Rear axle $20
Calipers $50
Front brake master w/lever $35
Right clip-on w/bar end $15
Lower triple $35
Water pump $30
Starter $35
Stator $40
Subframe $70
Lockset (gas cap, ignition switch, seat lock, key) $75
Left side switches w/choke cable $20
Right side switches w/throttle assy. cables $20
Rear shock (12xxx miles) $35
plastics around the guages and between tank and fairing, both sides.
left side (gear change side) drivers footpeg
A big thanks to the seller for taking the time to send me pics of the lower center fairing and understanding what a fussy SOB I am....He convinced me to buy new...so, the lower center is still available and a bump for a good guy...Hank
Basically it was stored outside in Florida sun for quite a long time, some parts have seen better days, some are mint/intact...Motor is trash, but there are few good things in it or on it...gauges are very good, headlight, full Yoshi pipe very nice (needs cleaning/polishing) very small dent underneath, on one of the header pipes, wheels, rotors, calipers, masters, clutch slave, plates w/pressure plate, starter, l & r fairings, upper, gas tank, tail section, seat (needs new cover), subframe shock, swingarm, harness etc....check photos, if you need photos/close ups or higher resolution - send me an e-mail or PM me...Plase dibs in this thread if interested. Number of my posts not saying much about me but if you would feel more comfortable dealing with me over e-bay - no problem, PayPal is cool, you pay actual shipping cost, no rape here.
SALE PENDING (still taking dibs)
Left side fairing
Stator cover
Rear cowl/tail section
Gauges???
Clutch master, line, slave??
100% Available:
Yoshimura RS-3 full system (have dibs TL7484)
Gauges (have dibs OrganDonor)
Front wheel
Rear wheel w/rotor, sprocket
Carbs (nice)
Front axle
Rear axle
Calipers
Lower triple
Water pump
Starter
Stator
Subframe
Seat (needs new cover)
I am new to this website and would like to get the entiire rear wheel assembly as well as the caliper. please advise what I need to do to make this happen
Here is a link to the rear wheel. http://cgi.ebay.com/ebaymotors/1997-98-CBR...=item4a9db1e3df Or PM him for further details
Left side fairing
Stator cover
Gauges???
100% Available:
Front wheel
Carbs (nice)
Front axle
Rear axle
Calipers
Lower triple
Water pump
Starter
Stator
Subframe
PM sent....Thanks
