Ronnie Posted September 20, 2003 Share Posted September 20, 2003 Local dealer doesn't carry the crush washer for the drain plug: What are the odds of leaking without replacing the crash washer? Quote Link to comment Share on other sites More sharing options...
Hookman49 Posted September 20, 2003 Share Posted September 20, 2003 I was changing mine every time. Hell now I change it about every third time. No problems. Ken Quote Link to comment Share on other sites More sharing options...
bar10dah Posted September 20, 2003 Share Posted September 20, 2003 Can't you just get one from a HomeDepot or Lowes? They're a 14mm something or other. What are they made out of?! I think I get them for something like 14 cents. I've heard quite a few people that never use them at all and have never had a problem. Quote Link to comment Share on other sites More sharing options...
JJP XX Posted September 20, 2003 Share Posted September 20, 2003 73k miles on mine, never replaced it and hasn't leaked....yet. Quote Link to comment Share on other sites More sharing options...
John01XX Posted September 20, 2003 Share Posted September 20, 2003 replaced my crush washer for the first time at 18,000 miles. Never leaked but bought a 6-pack for .90 cents from Honda just because we all should. Talking with a Honda mechanic, he told me no problem reusing the old one BUT you have to tighten the drain plug tighter and the threads at the bottom on the motor are not real strong, so the crush washer just makes it so that you dont have to tighten the plug so tight. For the .15 cost it is worth replacing, least I will from now on. Quote Link to comment Share on other sites More sharing options...
jrdxx Posted September 21, 2003 Share Posted September 21, 2003 DON'T get overenthusiastic with tightening the drain plug. You'll crush the washer beyond any possibility of reuse, and might strip the threads in the sump. Then you'll really hate yourself. Check the washer before reinstalling, and if necessary, clean the flat surfaces by wiping the washer over a piece of very fine (1000 or finer) sandpaper once or twice. Clean the washer thoroughly, and reinstall the plug and washer. Torque the plug only to the value given in the manual (22 lb-ft). Add oil and ride a bit; check the plug, if it doesn't leak, you're OK. Quote Link to comment Share on other sites More sharing options...
tomek Posted September 21, 2003 Share Posted September 21, 2003 After 15+ oil changes original washer still refuses to leak. Quote Link to comment Share on other sites More sharing options...
EVLXX Posted September 21, 2003 Share Posted September 21, 2003 You now somewhere on this site someone said ( and I don't know why I never thought of it) you don't have to buy a new washer, all you have to do is aneal the old one. Take a butain torch and lay the washer on something and heat that baby up until she is red hot, then quit, after it cools it's rejuvinated and ready for use. Thanks whoever that was! Quote Link to comment Share on other sites More sharing options...
PGA XX Posted September 21, 2003 Share Posted September 21, 2003 How about flip-flopping it every time? Kinda like Bush (There was no connection between Iraq and 9/11). WTF???? :shock: :shock: That was my favorite reason :mad: :mad: Quote Link to comment Share on other sites More sharing options...
molson309 Posted September 21, 2003 Share Posted September 21, 2003 I've successfully reused copper crush washers by annealing them before reuse: Heat with a blowtorch to red-hot and let cool. The washer work hardens from the tightening and the annealing removes the hardening, making it nice and soft to seal again. Sometimes you have to sand grooves off to make the surface flat. Works for aluminum too. Just don't overheat to the point of melting (the aluminum won't show any heat color like copper does) Quote Link to comment Share on other sites More sharing options...
bar10dah Posted September 21, 2003 Share Posted September 21, 2003 Torque the plug only to the value given in the manual (22 lb-ft). 22 lb-ft... is that one grunt, or two? I forget... Quote Link to comment Share on other sites More sharing options...
ironmike Posted September 21, 2003 Share Posted September 21, 2003 Not to belabor the obvious... A wrap or two of teflon plumber's tape on the threads of the bolt, with another more generous wrap at the base of the threads at the washer as it sits against the bolt head (holding the bolt vertically, threads up - allowing gravity to do its magic), will assure a leak-proof seal, and preclude any seizing/galling of the steel threads in the aluminum oil pan. You only need torque the bolt to 18-20 ft-lbs. My '99 is going on five years on the original washer with never a leak or seepage. :wink: Quote Link to comment Share on other sites More sharing options...
SwampNut Posted September 21, 2003 Share Posted September 21, 2003 Man, sometimes it's funny how the most mundane things get so much analysis. But anyway, I reuse them a few times then replace for peace of mind. No big deal. I had one leak once on another bike after about 5 changes, but it was a tiny leak. Quote Link to comment Share on other sites More sharing options...
Ronnie Posted September 21, 2003 Author Share Posted September 21, 2003 BTW which oil filter wrench you guys use? One I used wasn't the best in the world for sure. Quote Link to comment Share on other sites More sharing options...
RichardCranium Posted September 21, 2003 Share Posted September 21, 2003 Oil filter wrenches are for pussies. Though I do have to take off my left lower in order to be able to get a good grip on my filter when taking it off by hand. Quote Link to comment Share on other sites More sharing options...
bar10dah Posted September 21, 2003 Share Posted September 21, 2003 I don't use a wrench. I just reach up under my bike and loosen it by hand. I don't even take the fairings off! Quote Link to comment Share on other sites More sharing options...
SwampNut Posted September 22, 2003 Share Posted September 22, 2003 If I'm doing the change with a hot motor, I use a flat wrench which is pictured in the oil change page in the FAQ section of the site. Quote Link to comment Share on other sites More sharing options...
RodeRash Posted September 22, 2003 Share Posted September 22, 2003 You now somewhere on this site someone said ( and I don't know why I never thought of it) you don't have to buy a new washer, all you have to do is aneal the old one. Take a butain torch and lay the washer on something and heat that baby up until she is red hot, then quit, after it cools it's rejuvinated and ready for use. And....this is much easier and cheaper than replacing the washer? Quote Link to comment Share on other sites More sharing options...
CBR-RR-XX-CESS Posted September 22, 2003 Share Posted September 22, 2003 On both the XX and the 954 I found that a medium size pipe wrench will fit on the oil filter well enough with out taking the fairing off. On the 54 I do have to spread the fairing at the bottom alittle. Works as good as any filter wrench. Jeff Quote Link to comment Share on other sites More sharing options...
