seeten1 Posted May 18, 2006 Share Posted May 18, 2006 I have used this filter on my last oil change with Mobil 1 15-50 after 2500 miles the oil still has the color of honey. I have read alot about filters, from what I understand this is the best filter on the market. Quote Link to comment Share on other sites More sharing options...
OrganDonor Posted May 18, 2006 Share Posted May 18, 2006 +1 I'm using Mobil1 oil and filter, too. Quote Link to comment Share on other sites More sharing options...
redxxrdr Posted May 18, 2006 Share Posted May 18, 2006 Is M 108 the part number for the filter that fits the bird? Available at autoparts stores? Sounds interesting. Thanks, Craig Quote Link to comment Share on other sites More sharing options...
AZITPRO Posted May 18, 2006 Share Posted May 18, 2006 I have looked at the local autoparts store and could never find this filter, I have read it is the best though. Where did you buy it? Do you have a part number? Quote Link to comment Share on other sites More sharing options...
azxr Posted May 18, 2006 Share Posted May 18, 2006 I use the Mobil 1 M110 on my TRUCK and it is a great filter that I think fits Honda motorcycles. However, it may be just a little bit long and possibly hit the header on the XX. The Honda part number is 15410-MM9-013 and here is a reference for Honda alternative oil filters at the below site with the M110 mentioned. http://www.yft.org/tex_vfr/tech/oilfilter.htm I meant to add that I purchased a case of 6 off of this guy on Ebay smarge1978 http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=8033264410 for about $7 each shipped. He shipped quickly and I will purchase from him again. He seems to carry all sizes of M1 filters. Quote Link to comment Share on other sites More sharing options...
OrganDonor Posted May 19, 2006 Share Posted May 19, 2006 I forget which one i have on the bird... I believe 108 and 110 are the same except for the filter length. I think I may have the 110, as it's readily available at Autozone. Quote Link to comment Share on other sites More sharing options...
Jette Posted May 19, 2006 Share Posted May 19, 2006 I'm using the comparable Pure One. It is a little longer than stock, but fits fine otherwise! Quote Link to comment Share on other sites More sharing options...
Canadian Bird Posted May 22, 2006 Share Posted May 22, 2006 I'm using the comparable Pure One. It is a little longer than stock, but fits fine otherwise! I purchase a "high tech", billet, re-usable filter from Scott's in Cali, It was outrageously expensive by the time it arrived in Canada, but the "tech" who works on my bike, yes, I use the dealer where I bought the bike, suggested I stick with Honda OEM parts. Here it sits, looking beautiful, and I don't know whether to install it or not. Suggestions, has anyone use this product? Quote Link to comment Share on other sites More sharing options...
testrider Posted May 22, 2006 Share Posted May 22, 2006 I'm using the comparable Pure One. It is a little longer than stock, but fits fine otherwise! I purchase a "high tech", billet, re-usable filter from Scott's in Cali, It was outrageously expensive by the time it arrived in Canada, but the "tech" who works on my bike, yes, I use the dealer where I bought the bike, suggested I stick with Honda OEM parts. Here it sits, looking beautiful, and I don't know whether to install it or not. Suggestions, has anyone use this product? I wouldn't bother with it myself. Yes, I did look at it seriously a while ago and I asked myself: how the heck am I going to clean it? Even if I could, it'll be a bigger mess that just replace the filter (and now you will have to recycle the solvent that you use to clean it and also the used oil, instead of just the oil) Quote Link to comment Share on other sites More sharing options...
seeten1 Posted May 22, 2006 Author Share Posted May 22, 2006 I am pretty sure the M-108 is the filter for a Mazda RX-8 available at any Autozone. Quote Link to comment Share on other sites More sharing options...
Canadian Bird Posted May 23, 2006 Share Posted May 23, 2006 I'm using the comparable Pure One. It is a little longer than stock, but fits fine otherwise! I purchase a "high tech", billet, re-usable filter from Scott's in Cali, It was outrageously expensive by the time it arrived in Canada, but the "tech" who works on my bike, yes, I use the dealer where I bought the bike, suggested I stick with Honda OEM parts. Here it sits, looking beautiful, and I don't know whether to install it or not. Suggestions, has anyone use this product? I wouldn't bother with it myself. Yes, I did look at it seriously a while ago and I asked myself: how the heck am I going to clean it? Even if I could, it'll be a bigger mess that just replace the filter (and now you will have to recycle the solvent that you use to clean it and also the used oil, instead of just the oil) I didn't really think of this, I'm more concerned of the "filtration" ability, and is it really as good as Scott promotes? I let the dealer take care of the oil change but why do you think he suggested I stick with OEM? Thanks for your response, it make sence. Quote Link to comment Share on other sites More sharing options...
CBRBob Posted May 23, 2006 Share Posted May 23, 2006 FYI, the Purolator PL14612 is the same size as the Honda MM9 filter. The MM9 is the longer of the 2 filters Honda uses (the other being the MCJ). Quote Link to comment Share on other sites More sharing options...
RodeRash Posted May 23, 2006 Share Posted May 23, 2006 I didn't really think of this, I'm more concerned of the "filtration" ability, and is it really as good as Scott promotes? I let the dealer take care of the oil change but why do you think he suggested I stick with OEM? Thanks for your response, it make sense. Here are the standard replies. 1. The OEM Honda filter has have a valve that does not allow the oil to drain back into the engine. You don't know if that is true on your replacement filter. (engine wear issue) 2. The OEM filter has a bypass spring specified by Honda. The bypass spring in the replacement filter may not be setup to bypass at that same pressure level. (possible engine damage issue) 3. The generic filter may not filter per Honda specs. (engine wear issue) (NOTE: The shop guy does not know what the specs are for the Honda filter any more than you or I do.) 4. Your service guy didn't want to spend the time cleaning your new replaceable filter. (an oil change is a flat rate charge and it doesn't include time spent cleaning an aftermarket filter) 5. The service dept. didn't get to sell you a new filter. (dealer revenue issue) Quote Link to comment Share on other sites More sharing options...
