OK, same deal as last time, but everything's gone up a little... wire prices, connector cost increase, etc...
All prices include "low and slow" USPS shipping in the CONUS. The prices below are for Paypal or check by mail.
PM me for payment details
Connector alone, with female pins $7.50
Standard pigtail... I solder on (3) yellow wires, a red wire, and a green wire, 4" long leads, and pack the connector full of dielectric grease, so it's a solder wire to wire (or crimp, in a pinch) affair. $13.50
"Plug and Play" pigtail ('97 to '00)... Same as Standard Pigtail, but I solder (and heat shrink) the male terminals on the ends of the wires, so in a pinch (on the road), you can replace the R/R with a Yamaha unit, without crimping or soldering wires. $18.00
"Plug and Play" pigtail ('01 to '03)... Same idea as the early model plug and play, but with 33" long wires, as the R/R is located on the other side of the tail section. The late model 'birds also use (2) pins for ground and (2) pins for power, so I wire them together at the start, by the Yamaha connector. I will sell these for $26.00, but see below:
NOTE: The R/R is a piece of silicon that takes what it needs, and shunts the rest to ground. Honda did a good thing with the later model 'birds by using (2) connections for both GND and +B... Putting on a Yamaha R/R and replacing those (2) connections with (1) basically puts you in the same position as the earlier 'birds with Yamaha R/R's... Cal noticed (and told me about) that the terminal in the connector that is almost always fried is the Ground, which makes sense because the R/R shunts everything to ground that it doesn't need, so the Ground will have the highest current a lot of the time. My suggestion is to buy an OEM replacement R/R for your '01-'03 Blackbird, but I will make these if you want them, because I know the Yamaha R/R is much cheaper.
Mike
Nice work Mike.
Quality spade terminals, soldered and shrink tube.
Looks like you used mtw/awm wire?
Much better than my temporary connection.
PM sent.
Yep, 14AWG, MTW/THW/Oil Resistant/AWM wire... It's what we use on our conveyors at work. I just buy it from work, as we buy spools and it's cheaper than paying $2/foot at Radio shack for shitty wire...
Mike
BartonMD, do those connectors you get fit the pin-out on a stock XX R/R? I cracked up my connector and need a replacement...
No, they don't... That's why we can't just use our stock connector on the R1 R/R...
Also, I shipped the (3) orders that I got paypal'd for, yesterday...
Mike
  • 1 month later...
  • 2 months later...
  • 1 month later...
Is the R1 R/R better than the Honda XX R/R?
Based on the comments on this board, yes.
It is supposedly better than the first gen R/R, but it is $50 instead of the honda one being $160...
Mike
Mike, please send me a P&P for my '99. Thanks, they look great!
  • 1 month later...
bumpage from the 4th page (to answer a question that was answered above, that was sent to me in a PM)
Mike
  • 1 month later...
