XXMAN Posted July 6, 2012 Share Posted July 6, 2012 Ordered stiffer sprigs for front forks any recommendations on fork oil ? Quote Link to comment Share on other sites More sharing options...
TeXTrain99 Posted July 6, 2012 Share Posted July 6, 2012 Forks work better with it than with out it. My $0.02 only. Quote Link to comment Share on other sites More sharing options...
redxxrdr Posted July 7, 2012 Share Posted July 7, 2012 I pulled out my reciept from Cogent to see what they used. It shows "Spectro shock fluid VL". It doesn't specify weight. A search of the Garage showed suggestions of 5 to 10 weight. My mind thinks 7.5 weight is what went with the Penske cartridges. But that was quite a while ago. Longer than I want to admit. I hope Joe or Hank will post up with more seasoned recomendations. Quote Link to comment Share on other sites More sharing options...
XXMAN Posted July 8, 2012 Author Share Posted July 8, 2012 I think it's gonna be 7.5 thanks for all your help. Quote Link to comment Share on other sites More sharing options...
lensmanxx Posted July 8, 2012 Share Posted July 8, 2012 I had the SV front end done by Traxxion Dynamic- I think the oil is an 8 weight. Quote Link to comment Share on other sites More sharing options...
inline4 Posted July 9, 2012 Share Posted July 9, 2012 Ordered stiffer sprigs for front forks any recommendations on fork oil ? What springs did you order; brand; rate? Thanks. Jim Quote Link to comment Share on other sites More sharing options...
XXMAN Posted September 1, 2012 Author Share Posted September 1, 2012 Ordered stiffer sprigs for front forks any recommendations on fork oil ? What springs did you order; brand; rate? Thanks. Jim I ordered race tech 1.2 spring rate love them Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted September 1, 2012 Share Posted September 1, 2012 Mazola. Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted September 1, 2012 Share Posted September 1, 2012 Thanks for pulling this up, guys...sorry I missed it. I've been pleased with a 50-50 mix of the two Honda fork oils. Only from memory, one was 5wt and the other was 10wt, so theoretically the mix was 7.5, although it wouldn't surprise me if some quirk of oil law made it something slightly different. I've experimented with some ATF's as well, with interesting results. I'm hoping that my varied results and difficulty interpreting them is more a function of the vastly different roads and surfaces here in PA, rather than a serious numbness concerning what information comes back from my front wheel. Why ATF? A much greater range of viscosities, and about 1/4th the price. Fork oil is damned expensive unless you buy it in 5 gallon lots. Quote Link to comment Share on other sites More sharing options...
rockertom Posted September 2, 2012 Share Posted September 2, 2012 I am running the Sonic 1.1's in the forks. Used 10w with a 1/2" over book recomendation for height. I like the feel that this gives me on the frontend. No other mods to the forks. Quote Link to comment Share on other sites More sharing options...
