Warp11XX Posted August 13, 2011 Share Posted August 13, 2011 Dropped the Bird in the driveway last night. Rashed the left lower and cracked the plastic at the lower stay, badly scratched the starter clutch cover, and lightly scratched left mirror shell. What's the color code or best way to match the case cover paint? I plan on stripping the entire cover and sanding/polishing to remove the scratches from the casting. What paint is best to use for them? Also, any brand name recommendations on plastic repair gloop to fix the crack in the lower? I've heard that the 3M stuff is really good. Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted August 13, 2011 Share Posted August 13, 2011 :icon_wall: Quote Link to comment Share on other sites More sharing options...
FiXXation Posted August 14, 2011 Share Posted August 14, 2011 Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted August 14, 2011 Share Posted August 14, 2011 Don't know the code. Had a lowside in Montana a couple years back and even if you got the code, the cost of fixing it would be prohibitive. Go to your Wal-Mart of auto parts store and grab a can of spray touch up. Dupli-Color DSGM344 (Gunmetal Metallic) works nicely. Comes out a darkish metallic gray. The Honda color is this greenish gray NOTHING will match. Just take off the side panels, remove bolts and screws (and oil fill plug) and do a very good masking job and you can spray it on the bike with no problem. Gotta do both sides because it is noticeable if you walk around the bike. Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted August 14, 2011 Share Posted August 14, 2011 Sorry to hear Tom, two words... ENGINE ARMOR Got CF armor on both sides to protect the case covers. Also hides little scratches nicely from little spill overs in gravel. Quote Link to comment Share on other sites More sharing options...
