HERBXX Posted April 21, 2003 Share Posted April 21, 2003 I , with my brothers help installed the gold valve and rebound valves and springs It was a bit finickity (sp) but not too bad. Hints 1) measure EVERY SHIME 4 times!! , unless you like doing things twice (guess how i know) 2) wrapping a tie wrap around the teflon seal on the rebound valve makes it a snap to get it back in the cartridge. (the wrap pops off as it slides in) 3) don't do the job on good friday, cause its a pain when you find you need a new tool (like a long allen key (hex) key that you can some how put on you torque wrench) I used 1kg springs with 130 mm spacer for 24 mm of preload, reabound stack r20 , compression stack c38. It rides great and i'm please with the results . The only problem is the bolt in the bottom bolt in the forkleg is weeping a bit. (less then a drop in a 45 minute ride). I went easy tighting it as i couldn't get my socket allen key on it , and there fore couldn't use the torque wrench. I will fix that tonight after i get an 1/4 to 3/8 adapter. BTW . We didn't have to take the forks off the bike, just the front fender and wheel. :!: Quote Link to comment Share on other sites More sharing options...
SwampNut Posted April 21, 2003 Share Posted April 21, 2003 the bolt in the bottom bolt in the forkleg is weeping a bit. Did you replace the sealing crush washer on the bolt? It may need to be replaced. Quote Link to comment Share on other sites More sharing options...
HERBXX Posted April 21, 2003 Author Share Posted April 21, 2003 No not yet !! I agree they should have been replaced !! . The local dealer didn't have any. I ordered four last thurday, I couldn't believe they didn't have them in stock and I was already set up to do the job last friday so I did it anyway. If your carefull you can take those bolts out and the oil stays in so im not too worried about replacing them when i get the seals. If they don't come in soon and the retorqing doesn' t help , I have to get somebody to measure one and i'll buy a box of them from an industrial supply company. I suspect that the 8mm id , 11.5 od by 1.5 mm think would do the job . If anybody has one laying around it would be great if they could measure it for me Thanks Herb Quote Link to comment Share on other sites More sharing options...
