jon haney Posted June 14, 2010 Share Posted June 14, 2010 anyone know if i need the speciality tools to remove the motor? I didn't use anything special. Well, my friend Joe has been called "special" before, but that's another story. Putting the motor back in will require a special socket (can't remember the proper term) for the two rear engine mounts, but you can make that out of an old hex socket using a dremel, die grinder, and/or hack saw. Ok so I shouldn't by the socket You can if you want. Just pointing out a less expensive alternative. Quote Link to comment Share on other sites More sharing options...
Wetzel Posted June 15, 2010 Author Share Posted June 15, 2010 Finally got the motor and dropped the old one out. Quote Link to comment Share on other sites More sharing options...
Wetzel Posted June 16, 2010 Author Share Posted June 16, 2010 Now i just have to get the motor back in the bike torque the clutch basket down and the drive sproket on the motor and I should be on the way to firing it up Quote Link to comment Share on other sites More sharing options...
