Wetzel
Everything posted by Wetzel
It pops out when throttle is applied. If I let off it will jump back in to gear. Splitting the case is not what I wanted to hear. However, I just happen to have an extra motor and trans sitting in my house.
Anyone have the problem with the bikes jumping in and out of gear, this is an 03 black bird with 69k on it. I haven't check the clutch or the rod for the clutch lifter yet.
I would start with the cam chain tensioner. There cheap and Easy to replace. It sounds like mine did when I changed motors out.
is there a way to just tip the front of the motor down
Wetzel replied to Wetzel's topic in The Garage
Great info Stan. -
Sorry I haven't been able to post School is keeping me busy . I found a machine shop that can get the bolt out by electrical destruction. Not sure what that means but for now im going to swith the heads out till i can afford to have them do the work on it. I was going to work on the bike and get some pictures on Thursday but we had a good storm and i got water in the basement. I will post pictures as soon as i can. -
I'll post a picture. I already tried the left hand drill bit. I needed to tilt the motor to get to the bolt. -
New problem. My EzOut broke which never happens to me. Any Ideas on how to get the bolt out now ? -
sweet thanks -
Alright I have an oil leak comming from the cylinder head cover. It appears that I over torqued a bolt up there . So i need to gain a better angle so i can drill and easy out the bolt. Is it possible to just drop the exhaust and unbolt the front of the motor from the frame and tilt it down?
Well the cycle is back up and running for now
Im looking to get $80 or best offer for this part + shipping. I do not have the wiring harness for it.
+1 I have read on up on them. I don't know if i can do this one. It will cost 300 to have it taken care of by the pro's
IT IS RUNING. But not like it should be. It will not idle. It reminds me of my harley I use to own in that way. Valves need to be adjusted Which I am not going to do. I will be sending it in to the shop for that.
It does turn over. It has good compression. I will have to check for spark. Im assuming it would have spark since I used my coils. The head gasket Gaged the same thickness from the blown motor to the other one. I just went out and bought new plugs. Im going to change them and hope for the best. How would i check the timming? Well that is going to be a little harder, but a timing light will work with a induction pickup. When you pull the plugs stick one in the coil wire and touch it to some metal and turn over looking for a spark first, or just hold it and see if it shocks you.... Also, a little gas sqirted in the carbs will deal with gas flow problems, Check that alll your plugs are connected well. On top of the motor. Nothing pinched. by the frame, and motor. Make sure that you have put the plug wires on the right plug. And that the correct coil wire is to the + side of the coil. Got the ground wire on the frame and starter tight. I forget is it carbed or Fi. check all your fuzes including the one under the red cover... I'm working on changing the plugs right now. I did get it to run for a few sec's. First three plugs are WET. Which is not a problem I bought new plugs just neglected to put them in Well changed the pluged and now it seems to want to start even more. I will work on it alittle later dinner time
Well It would have been sooner but we had some people come over. There is a new problem the bike doesn't want to run. I have checked the following 1 all electrical connections 2 vacum line is correct 3 pulled a fuel line to make sure fuel was flowing. IT IS Anyone one else have ideas
And 8 hours later [ The motor is in the bike and everything is hooked up. We turned the motor over. Tomorrow will be the day I fire it I hope.
hopfully tonight i can put it in.
Well Im going to try to change it so it fits my wiring harness Just bolt the old cover on and use the trigger plate from the old bike. There's no point in switching the sensor to the other cover. I did that already. the motor is sitting there waiting to be reinstalled.
well thats not good for me
I know its somthing for a timming has anyone used one of these before
Well Im going to try to change it so it fits my wiring harness thats fine, post pictures of the aftermarket one, someone might want it I used the old one because I don't have to correct plug on my wireing harness corrected for Texan translation I will post another picture of it
Well Im going to try to change it so it fits my wiring harness thats fine, post pictures of the old one, someone might want it I used the old one because I don't have to correct plug on my wireing harness
Help!! Should I rebuild the motor or find a used one?
Now i just have to get the motor back in the bike torque the clutch basket down and the drive sproket on the motor and I should be on the way to firing it up
