Bird won't start
ZRX1100JIM
put a volt meter on the battery and try to start and see what the volts go down to
Pull the cover on the right and make sure the motor over without the plugs in.
You may have a major problem
:icon_thumbsup: +1
Starter relay chatters like hell but won't engage starter. I did a search
and found nothing. Honda service manual is useless in this case.
Fully charged battery.
Any help would be appreciated.
Are you saying that the relay chatters while you hold down the start button? If so, then either a bad battery or poor battery connection is most likely the culprit. Check both ends of both battery cables, loosen and retighten the connections.
If the battery is weak, then jumping it will be the best test of that.
Thanks Mike
That's what I found out. Weak battery. I put a new Die Hard AGM in it last year.
The bike sat for a week and drained enough to be to weak to start the bike.
Hadn't heard that "chatter" sound for so long I'd forgotten what it indicated.
I swapped out the battery from the ZRX and it fired right up. Now I have to
find out if its a faulty battery or something besides the clock is drawing voltage
from the battery.
My ZRX is a '00' with original battery that I rarely ride since getting the Bird
and I've never had it on a Tender. Probably won't last much longer now.
