ZRX1100JIM
Everything posted by ZRX1100JIM
  1. [quote name='redxxrdr' I THINK, maybe, that the cluster lamps are held in with sockets. I use a simular setup on some of my Xray machines. Rotate the socket 90 degrees and the bulb and socket pull off the back of the cluster. Pull the bulb out of the socket and replace with a new bulb. The replacement LED's for '97'/'98' are 6 each #74 and 4 each #194. The way it looks is the smaller #74's are for the idiot lights and the larger #194's are for the tach/speedo illumination. Ill let everyone know for sure after the LED's come in.
  2. redxx Its a '97'. And yes, mine is dim enough to make it hard to see at night. Para It seems that there is a loose connection in that plug.
  3. Can someone tell me how to remove the two large rectangular plugs on the back of the instrument panel. I don't want to just go yanking on them. My speedo light wasn't lit and when I wiggled the harness that goes to the left plug, the light lit again. I want to take it apart to see whats up and change the bulbs to led's. Thanks Jim
  4. I did this Mounts right under speedo with velcro. Wired straight to battery with inline fuse. I also incorporated a plug for easy removal. I purchased the box & switch at Radio Shack. The voltmeter I got here voltmeter Sure looks like a Datel. The box is approximately 2.78"x1.78"x1".
  5. ZRX1100JIM
    R/R
    My stock r/r shit the bed a couple of weeks ago. I've replaced it with an R1 r/r. I've never thought of reaching down and touching the r/r. Well, after a 6 mile ride I felt the r/r and it was pretty hot. Out of curiosity i bought one of those infra red temp gauges. The r/r was 161* F. I've checked all the wiring and cleaned all the grounds. 13.2 with key off. 12.8 with key on. 14.1 at 5000 rpm. Are these things supposed to get this hot. Cause I have nothing to compare it to. I just ordered another one to keep under the seat as a spare. I also ordered a DATEL.
  6. I have a '97' bird. Last night I noticed the speedo light was out. Has anyone changed the stock bulbs out with LEDs. Looks like its going to be a real pain in the ass to change, so I'd like to replace them with something that lasts. They never did seem real bright to begin with. Any help will be appreciated. Thank you Jim
  7. Thanks Mike That's what I found out. Weak battery. I put a new Die Hard AGM in it last year. The bike sat for a week and drained enough to be to weak to start the bike. Hadn't heard that "chatter" sound for so long I'd forgotten what it indicated. I swapped out the battery from the ZRX and it fired right up. Now I have to find out if its a faulty battery or something besides the clock is drawing voltage from the battery. My ZRX is a '00' with original battery that I rarely ride since getting the Bird and I've never had it on a Tender. Probably won't last much longer now.
  8. Starter relay chatters like hell but won't engage starter. I did a search and found nothing. Honda service manual is useless in this case. Fully charged battery. Any help would be appreciated.
  9. This place has pretty good prices. I don't think anyone else is cheaper. www.motoxoutlet.com
  10. I have them, let me dig up a picture... Contact John01XX on this site. He is a Clear Alternatives rep. Thank You J.B.
  11. Does anyone have smoke lenses on a "black" bird, and where did you get them. TIA.
