lifeisnow Posted April 5, 2008 Share Posted April 5, 2008 dear xx bikers I ride a 2000 blackbird and today i rode a 98 model, i noticed that my dashboard has play and it moves while the dashboard on the 98 model is pretty fixed and has no play at all. is it normal to have this play in the dasboard? i am askind cause i have a certain light noise coming from thr front are on certain road surfaces which i have not solved yet. next week i am changing the front springs to hperpro pprogressive ones maybe i solve this damn noise lifeisnow is offline Quote Link to comment Share on other sites More sharing options...
BearXX Posted April 5, 2008 Share Posted April 5, 2008 Someone should see a shrink. They hear noises while driving a perfect bike. Hope you find the problem. Quote Link to comment Share on other sites More sharing options...
willxx23 Posted April 5, 2008 Share Posted April 5, 2008 Mine (00 model) had some play prior to me installing the HID's but I used one of the attachment points for the gauge cluster to secure one of the ignitors, that took up any play left in the gauge cluster. I do know some people have added washers or rubber to that point to get the same effect, it wouldn't hurt to add some and see if you like the results. Quote Link to comment Share on other sites More sharing options...
XXSIVSPD Posted April 5, 2008 Share Posted April 5, 2008 My '00 has some play in the cluster. Not so much that it moves noticably while riding but enough I can move it by hand. Quote Link to comment Share on other sites More sharing options...
XXTi Posted April 5, 2008 Share Posted April 5, 2008 I added a rubber washer to my instrument cluster mounts years ago. Just pop the windshield off and you can see what you need to do. Quote Link to comment Share on other sites More sharing options...
lifeisnow Posted April 6, 2008 Author Share Posted April 6, 2008 i did check the dashboard today and its mounted in place and all gommets are there, i also replaced the fairing poppers with new once and the damn noise is still there, i am only hoping i wont hear it again ehen i change the front springs to progressive once next week Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted April 7, 2008 Share Posted April 7, 2008 Wear foam plugs in your ear. It not only protects your hearing but it blocks the "little noises" every bike makes. It a noise is loud enough to be heard through the plugs, then you need to worry about it. FWIW, I think all dashboards move. They are anchored through rubber grommets and are intended to move a little so the vibrations of the road don't rattle things to bits. Quote Link to comment Share on other sites More sharing options...
Hooplehead Posted April 7, 2008 Share Posted April 7, 2008 1997 w/20k dash seems tight still on mine. You could always keep your hands off it and watch the road instead?! Quote Link to comment Share on other sites More sharing options...
