Furbird Posted October 16, 2007 Share Posted October 16, 2007 What injectors fit the bird? I remember someone saying that factory S2000 injectors are the same size and could possibly even be an upgrade for the bird. If so, what year range should I look for? Quote Link to comment Share on other sites More sharing options...
MrBadExxample Posted October 16, 2007 Share Posted October 16, 2007 *.com link Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted October 16, 2007 Share Posted October 16, 2007 Under important threads.... Quote Link to comment Share on other sites More sharing options...
Para045 Posted October 16, 2007 Share Posted October 16, 2007 Are you going to Turbo your XX That is really the only reason you would need the bigger injectors Quote Link to comment Share on other sites More sharing options...
Furbird Posted October 16, 2007 Author Share Posted October 16, 2007 I might turbo in the future, but right now I think I have an injector leaking. Gas mileage has started going down, the bike smells rich, and I popped the oil cap off and it smells like fuel is making it to the crankcase. I swapped out my pressure regulator for one on another fuel rail I had, and the problem is still there. So, I'm going to try the regulator test I found (pull return line and if fuel sprays out without the engine running it's bad) on both regulators. If they both fail, that's the issue. If they both pass, then I'm going to replace the injectors. I do have a spare set of used stock injectors (same rail as the regulator came off of), but it's always nice to know what injectors I can use that I don't have to pay 3 times the cost of as a replacement on the bike. I can't think of any other reason why it would be dumping fuel, so if you guys can help out with some ideas, let me know. Quote Link to comment Share on other sites More sharing options...
Furbird Posted October 16, 2007 Author Share Posted October 16, 2007 Well, splash that idea, as that writeup says it would have to be controlled down by a PCIII or the like, and I don't have one. So I guess it will be stock or nothing until I decide on a turbo. Quote Link to comment Share on other sites More sharing options...
jon haney Posted October 16, 2007 Share Posted October 16, 2007 I read somewhere that the Suzuki Hayabusa also uses the same injectors. You could probably get some pretty cheap on Ebay. Quote Link to comment Share on other sites More sharing options...
