Mitch_1100xx Posted September 25, 2006 Share Posted September 25, 2006 im sure it has been posted a 100 times, but i was wondering does anyone know the weight of the full stock exhaust system is, trying to shed some lbs here. Quote Link to comment Share on other sites More sharing options...
Keith Posted September 25, 2006 Share Posted September 25, 2006 Look in the Important/Useful Threads section, you'll find this: http://www.cbr1100xx.org/forums/index.php?showtopic=9458 Quote Link to comment Share on other sites More sharing options...
Mitch_1100xx Posted September 25, 2006 Author Share Posted September 25, 2006 ah didnt see that thanx alot i appreciate it. Quote Link to comment Share on other sites More sharing options...
silverbird1100 Posted September 25, 2006 Share Posted September 25, 2006 Put a light full system on and you can actually tell a difference pushing it around the garage Quote Link to comment Share on other sites More sharing options...
Mitch_1100xx Posted September 25, 2006 Author Share Posted September 25, 2006 well as some of you know i was planning on putting the d&d drag pipe, which has gotta be one of the lightest (and some would argue cheapest quality) exhausts out there so i was trying to size up exactly how much weight i would lose, which i understand to be around like 25-30 lbs which is serious weight. i didnt relize just how massive the stock pipes are. i was wondering just genrally , those of you with full systems and a k and n filter if you are producing a descent amount of power. if you lose the centerstand and heavy kickstand and replace it with a billet one, you can lose huge weight and probably get the same speed or close to that of the zx12 or busa. if you drop like 25-30lbs and produce around 5 rwhp (there abouts) it should give the xx a young feel again. Quote Link to comment Share on other sites More sharing options...
sokanxx Posted September 25, 2006 Share Posted September 25, 2006 I dont know what gearing your currently running, but in the Quarter mile a 16T front sprocket makes the XX much faster. Since most of us only run in the low 130mph's in the quarter the 16t is a good option, and with a little practice launches can be very powerful and efficient, this should help in your hunting of ZX12's and busas Quote Link to comment Share on other sites More sharing options...
Mitch_1100xx Posted September 26, 2006 Author Share Posted September 26, 2006 I dont know what gearing your currently running, but in the Quarter mile a 16T front sprocket makes the XX much faster. Since most of us only run in the low 130mph's in the quarter the 16t is a good option, and with a little practice launches can be very powerful and efficient, this should help in your hunting of ZX12's and busas actually what i did was went with 18 in the front. i find with the stretch the back end breaks crazy and the revs come up instant with anything less. plus when i run the nitrous, the lower gearing goes to quick. off the line i already rip stock busas off the line, but at this point ide like to run them in top end. if i can drop weight and add like 15 hp through some smaller stuff then with the 40 shot i should be able to rip them in the top end to. When i get a good 5000 rpm launch (though i usually dont do that) the high gearing and rpms make the bike so fast, and if i can drop weight and gain some power then it should feel like i have a 16 tooth. oh yea i get way better gas milage!!! lol Quote Link to comment Share on other sites More sharing options...
beondwacko Posted September 26, 2006 Share Posted September 26, 2006 Mitch; If you really want to dump some weight then ditch the factory headpipe along with the factory cans. THe factory headpipe is a bit restrictive around the collector which an aftermarket pipe like and Akro totally solves. THe slip on's are typically worth 4-6 hp at best over the slip on's. Either or, you'll want to get it mapped. BTW, On motor, what are your best times and mph ? Quote Link to comment Share on other sites More sharing options...
Mitch_1100xx Posted September 26, 2006 Author Share Posted September 26, 2006 Mitch; If you really want to dump some weight then ditch the factory headpipe along with the factory cans. THe factory headpipe is a bit restrictive around the collector which an aftermarket pipe like and Akro totally solves. THe slip on's are typically worth 4-6 hp at best over the slip on's. Either or, you'll want to get it mapped. BTW, On motor, what are your best times and mph ? in all honesty i really dont know, ive done alot to the bike since the last time i checked, like it wouldnt even be close anymore. see i plan on ditching the whole stock exhaust engine back. and replacing it with the d&d pipe then ill get the bike dynod and mapped. i hope to around 190 rwhp with nitrous. they say a bone stock one makes like 135 rwhp or somthing. when and if i get this all done, beginning of next season im gunna hit the strip, get some official times. Quote Link to comment Share on other sites More sharing options...
