XXTi Posted July 4, 2006 Share Posted July 4, 2006 I have a couple of Fiamm horns to mount. They won't fit in the original horn mounting area and I'm curious where you guys have mounted yours. Quote Link to comment Share on other sites More sharing options...
John01XX Posted July 4, 2006 Share Posted July 4, 2006 I just mounted one in place of the OEM. Your right two won't fit tho. Quote Link to comment Share on other sites More sharing options...
OrganDonor Posted July 5, 2006 Share Posted July 5, 2006 I mounted my Stebel Nautilus horn in the tail section, against the brake light, the horn pointing towards the right side of the bike. Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted July 5, 2006 Share Posted July 5, 2006 Not that I've tried this but you should be able to mount one inside the cowl right under the headlight. Quote Link to comment Share on other sites More sharing options...
XXTi Posted July 5, 2006 Author Share Posted July 5, 2006 Not that I've tried this but you should be able to mount one inside the cowl right under the headlight. I was thinking about that spot too. There's room, but I don't know how it would sound. Quote Link to comment Share on other sites More sharing options...
OrganDonor Posted July 5, 2006 Share Posted July 5, 2006 Like a gay Fiamm horn, duh. :icon_duh: How goes the rainbow XX sticker production, Charlie? Quote Link to comment Share on other sites More sharing options...
gharknes Posted July 5, 2006 Share Posted July 5, 2006 mine are under the tank Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted July 5, 2006 Share Posted July 5, 2006 I have one on each side of my head. Quote Link to comment Share on other sites More sharing options...
John01XX Posted July 5, 2006 Share Posted July 5, 2006 I have one on each side of my head. And a pitchfork in hand !! The Devil Horns and forked Tail are my top selling "Awesome Ears" Quote Link to comment Share on other sites More sharing options...
XXBIRD Posted July 5, 2006 Share Posted July 5, 2006 One in between the forks in front using the OEM location the other one inside the lower cowling, partially in front of the radiators using the bolt which secures the oil cooler to the radiator. Quote Link to comment Share on other sites More sharing options...
John01XX Posted July 5, 2006 Share Posted July 5, 2006 One in between the forks in front using the OEM location the other one inside the lower cowling, partially in front of the radiators using the bolt which secures the oil cooler to the radiator. Great idea for the second one. I have my matching seond horn laying on the shelf in my shed. Now where to put the relay to run both horns ? Quote Link to comment Share on other sites More sharing options...
XXTi Posted July 5, 2006 Author Share Posted July 5, 2006 I have one on each side of my head. Quote Link to comment Share on other sites More sharing options...
XXTi Posted July 5, 2006 Author Share Posted July 5, 2006 Like a gay Fiamm horn, duh. :icon_duh: Some horns don't sound right unless they're mounted to a hard surface. The fairing isn't very stiff under the headlight. Quote Link to comment Share on other sites More sharing options...
Texhoss Posted July 5, 2006 Share Posted July 5, 2006 I have been wanting a Fiamm Horn, how much trouble is it to install, and is rewiring is required? Don't they sound like a GM car horn? Quote Link to comment Share on other sites More sharing options...
XXBIRD Posted July 5, 2006 Share Posted July 5, 2006 Now where to put the relay to run both horns ? Clutch line clamp bolt on the left side of the main head. My first relay got busted though during the ride on the way back from SEXXT (non-stop rain). Second time around, I opened it up and sealed with silicone pretty good. We'll see how long it would last. Quote Link to comment Share on other sites More sharing options...
