thetart Posted June 30, 2006 Share Posted June 30, 2006 Hi all the day after my bikes 25k service, I've been out for a blast in the country, only to find after I got there stopped the bike and had a cuppa, it wouldn't start again. 80 mile from home, the thought ... dam went through my mind. I've diagnosed the fault to two things, the rectifier/regulator and the battery. The rec/reg was pumping out silly voltage which cooked the battery which emptied the acid... all over the road I guess. There was none left in there when I checked. Once I was finally up and running again, I checked my speedo which said 0mph as I was doing 60 (ish ... maybe I guess) down the country lanes. Once back I've took the speedo apart to find out whats wrong. big picture here http://wayne.shacknet.nu/general/100_1816.jpg Possibly a question for someone with a street fighter as it is easier to get to the clocks, anyone any idea what was written on the component on the right hand side and is it a resisitor or diode. The chip on the board still works, I've tested that, but can't read what was written on that component. Anyone with a carb model Bird any idea (or FI model that uses analogue clocks) willing to have a look. Once I've got it working, (I am going to get it working. I'm not paying £200 for a new circuit board) am I allowed to post back what component values were to help out other people with the same problem, or am I breaking the site rules? Cheers A very sad Wayne Quote Link to comment Share on other sites More sharing options...
exskibum Posted June 30, 2006 Share Posted June 30, 2006 You're in luck -- I happen to be in the middle of putting my '97 back together, and it was only a few screws to get to. Next to and just outboard of your fried component, on the board itself, is the notation: R2 On the component that is fried, it reads: 180 J M 1W -- arranged exactly like that, except that the M in the lower line is inside a square with rounded corners. Good luck -- a burned up rectifier can do a lot of damage. Quote Link to comment Share on other sites More sharing options...
exskibum Posted July 1, 2006 Share Posted July 1, 2006 Once I've got it working, (I am going to get it working. I'm not paying £200 for a new circuit board) am I allowed to post back what component values were to help out other people with the same problem, or am I breaking the site rules? Sure, post it up -- info is always good, and I can't imagine how that would violate a board rule -- not like there are many rules in this anarchistic cyber place anyway. Quote Link to comment Share on other sites More sharing options...
thetart Posted July 1, 2006 Author Share Posted July 1, 2006 You're in luck -- I happen to be in the middle of putting my '97 back together, and it was only a few screws to get to. Next to and just outboard of your fried component, on the board itself, is the notation: R2 On the component that is fried, it reads: 180 J M 1W -- arranged exactly like that, except that the M in the lower line is inside a square with rounded corners. Good luck -- a burned up rectifier can do a lot of damage. He's a very nice man. Thanks for that. :icon_thumbsup: Right off to Maplins to go and get a new one. I'll post back hopefully with happier news. Cheers Quote Link to comment Share on other sites More sharing options...
