Toynut Posted May 20, 2006 Share Posted May 20, 2006 I plan to install a half HID H7 kit on my low beam so that I will be able to run a modulator on my high beam stock halogen capsule. I was wondering if anyone has figured this out yet, as the low beam typically stays on with the high beam? A Kisantech headlight modulator should work (I use them on all my bikes), but I want to minimize/avoid cutting and resplicing headlight wiring if at all possible. :icon_doh: Do you have to split the headlight circuits to be independent of each other? Any ideas before I start to dig in to the wiring circuits would be greatly appreciated. If anyone else has done this, what Kisan modulator kit did you end up using? Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted May 21, 2006 Share Posted May 21, 2006 Couldn't you just hook it up to the highbeam put your highbeam on? Quote Link to comment Share on other sites More sharing options...
nickc2s Posted May 21, 2006 Share Posted May 21, 2006 The high and low beam bulbs/wiring are separate from the factory. Install the modulator to the high beam wiring, and the HID to the low beam. Do a search for the HID group buy for install info Edit: Group buy thread resurrected, scroll down on this page Quote Link to comment Share on other sites More sharing options...
bhanxx Posted May 22, 2006 Share Posted May 22, 2006 Yep, just wired the Signal Dynamics modulator to high and HID to low, no problemo, works great... Quote Link to comment Share on other sites More sharing options...
Toynut Posted May 22, 2006 Author Share Posted May 22, 2006 I have used signal dynamics modulators in the past, though I prefer the Kisan plug and play units for their ease of installation. Has anyone used a Kisan in this particular combination yet? If so, which model (part #), did you install ? BTW bhanxx, Your still lighting off the low beam(HID), as well as flashing the high beam (on the modulator) at the same time, right? Quote Link to comment Share on other sites More sharing options...
bhanxx Posted May 22, 2006 Share Posted May 22, 2006 I have used signal dynamics modulators in the past, though I prefer the Kisan plug and play units for their ease of installation. Has anyone used a Kisan in this particular combination yet? If so, which model (part #), did you install ? BTW bhanxx, Your still lighting off the low beam(HID), as well as flashing the high beam (on the modulator) at the same time, right? Yep, no problem. I rarely ride at night when i can use hi, so i just did the lo HID which works fantastic for nite riding and i run modulating hi during the day. The yellowish modulating halagon hi really contrasts with the white bright HID lo and makes u conspicious. Oh yeah, the Signal Dynamics modulators are more difficult to install, but ya gotta luv da extra features and flexibility. Quote Link to comment Share on other sites More sharing options...
RXX Posted May 22, 2006 Share Posted May 22, 2006 I have the Comagination unit on mine. I have it hooked into high beam, HID is low beam. I have the low beam switched, so I do not have to run it during the day. I am sure the modulator makes me annoying as stink on rides. Doug, what do you think? Did the modulator make my ass look fat yesterday? Quote Link to comment Share on other sites More sharing options...
