Pete in PA Posted April 23, 2006 Share Posted April 23, 2006 Has anyone mounted a Fiamm Freeway Blaster horn in the stock location? Is there enough room without hitting the fender at full fork compression? Only $15 from Aerostitch catalog. Quote Link to comment Share on other sites More sharing options...
Warchild Posted April 24, 2006 Share Posted April 24, 2006 Has anyone mounted a Fiamm Freeway Blaster horn in the stock location? Is there enough room without hitting the fender at full fork compression? Only $15 from Aerostitch catalog. I did this mod several years ago. It fits fine. Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted April 24, 2006 Share Posted April 24, 2006 I have also done this. Makes your bike sound like a Buick. I had a small issue of the horn rubbing the cowl when turning the bars, alittle bending of the bracket and its fine. I also took it off after a yr of using it and put my stocker back on. the higher pitched BEEP BEEP caught more attention than the Buick sound. Quote Link to comment Share on other sites More sharing options...
OrganDonor Posted April 24, 2006 Share Posted April 24, 2006 I went with a Nautilus stuck in the rear of the tail by the license plate.... much nicer euro air horn sound. Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted April 24, 2006 Author Share Posted April 24, 2006 Great, a Buick sounds good to me. I'm going to check the auto parts stores for the low 500HZ Fiamm. Quote Link to comment Share on other sites More sharing options...
bpg Posted April 24, 2006 Share Posted April 24, 2006 make sure you test it first (maybe they'll even let ya test it right off a battery in the store). The first Fiamm I got from Advance Auto was a "Low-tone" horn that looked and sounded 'zactly like the stocker... Traded it for the bigger Fiamm air horn-lookin' one (likely the one you're looking at) and it was louder and deeper, and fit just fine... Wish I could remember the part #, but basically it was of a sorta spiral design in black plastic, and mounted/wired just like the stocker.. Advance or Pep boys should have it.. Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted April 26, 2006 Author Share Posted April 26, 2006 make sure you test it first (maybe they'll even let ya test it right off a battery in the store). The first Fiamm I got from Advance Auto was a "Low-tone" horn that looked and sounded 'zactly like the stocker... Traded it for the bigger Fiamm air horn-lookin' one (likely the one you're looking at) and it was louder and deeper, and fit just fine... Wish I could remember the part #, but basically it was of a sorta spiral design in black plastic, and mounted/wired just like the stocker.. Advance or Pep boys should have it.. That's the one I'm looking at. I went to Advance Auto yesterday and almost bought it then asked the counter guy if it doesn't fit can I return it. He said no. He then goes out with me to my bike and we both look at it and decide it won't fit. He coincidently has a Gold Wing. Keep in mind I've got my forks set at 45mm above the tree per hyperpro. Do you have it mounted so it points straight ahead? Do you still think it will fit? Quote Link to comment Share on other sites More sharing options...
bpg Posted April 27, 2006 Share Posted April 27, 2006 make sure you test it first (maybe they'll even let ya test it right off a battery in the store). The first Fiamm I got from Advance Auto was a "Low-tone" horn that looked and sounded 'zactly like the stocker... Traded it for the bigger Fiamm air horn-lookin' one (likely the one you're looking at) and it was louder and deeper, and fit just fine... Wish I could remember the part #, but basically it was of a sorta spiral design in black plastic, and mounted/wired just like the stocker.. Advance or Pep boys should have it.. That's the one I'm looking at. I went to Advance Auto yesterday and almost bought it then asked the counter guy if it doesn't fit can I return it. He said no. He then goes out with me to my bike and we both look at it and decide it won't fit. He coincidently has a Gold Wing. Keep in mind I've got my forks set at 45mm above the tree per hyperpro. Do you have it mounted so it points straight ahead? Do you still think it will fit? Why the fook can't you return it?? I do that all the time at our Advanced Auto, they'll even let me take stuff out of the package and see if it fits! Crazy... Anyway, yes, mine faces directly forward.... I believe I had to "re-route" the wires (which took all of 10 seconds), and it doesn't touch a thing lock-to-lock. Not sure about fitting with the Hyperpro set-up though - you need to go in when a jack-ass isn't working the counter, LOL! Next time you're in Clarion, PA, try their Advance Auto.. Quote Link to comment Share on other sites More sharing options...
XXBIRD Posted April 27, 2006 Share Posted April 27, 2006 I had a pair of Hi/Lo Blasters (130dB) installed recently. I had Fiamms but they were not loud enough. One of them goes in front of the OEM but up in front of the header. If you tweak it patiently, you find the right spot w/o any touching to plastic. The second one is located on the left side, partially in front of the oil cooler. I also used a relay not to fry the horn button. Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted May 1, 2006 Author Share Posted May 1, 2006 With much fabbing of the bracket I got it in there but it was hard to clear the brake hoses that cross the fender at full fork compression. I'm fighting the urge to tweak the screw in the horn. It sounds decent but seems like there could be more sound to be had. Screw has sealant on it. Quote Link to comment Share on other sites More sharing options...
PlasticxxHead Posted May 2, 2006 Share Posted May 2, 2006 Do we need a relay? or can we just plug and play? I have had these horns in my hand at my auto parts store and keep wanting to buy them , then decide against it.. I don't wanna fry my horn switch, but I have enough crap hooked up to my battery as it is... Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted May 2, 2006 Author Share Posted May 2, 2006 Plug and play. Except for the bending and cutting of a longer mounting slot in the horn bracket. I just stuck my head under the front of my 99 Monte Carlo. Same exact horn but there are 2, a high and low tone. Wish I could get another one mounted in my XX somewhere. Quote Link to comment Share on other sites More sharing options...
bhanxx Posted May 2, 2006 Share Posted May 2, 2006 Do we need a relay? or can we just plug and play? I have had these horns in my hand at my auto parts store and keep wanting to buy them , then decide against it.. I don't wanna fry my horn switch, but I have enough crap hooked up to my battery as it is... Definitely do the relay, i believe the horn will be louder too, someone correct me if i'm wrong. Plus reduce risk of frying oem wiring (which is considerably thinner than wiring recommended by horn mfg). Hooking up relay is super simple. Horn leads go to 85 and 86 (doesn't matter which, plug'n'play), incoming hot lead hooks to 30 and outgoing hot lead to horns hook to 87. Note: If running hot lead direct from battery (to relay 30), make sure the fuse is very close to battery to keep unfused wiring as short as possible. This is another huge advantage of auxiliary fuse block, all your wiring is protected. Sounds like it's time for auxiliary fuse block and some barrier strips from Radio Shack. Blue Sea has some really nice fuse blocks for reasonable price plus some that have have grounding integrated. Quote Link to comment Share on other sites More sharing options...
OZDave Posted May 2, 2006 Share Posted May 2, 2006 Thanks bhanks, where were you when I needed you. :icon_snooty: (gps install) Quote Link to comment Share on other sites More sharing options...
cbracerx Posted May 5, 2006 Share Posted May 5, 2006 Has anyone tried one of these? Stebel Nautilus Compact Dual-Tone 12-Volt Air Horn, 139 dB (twistedthrottle.com for $35.95) http://www.twistedthrottle.com/trade/productview/2137/ I ordered one, so I'll let you know how it works out... Quote Link to comment Share on other sites More sharing options...
