blacksheep Posted April 10, 2006 Share Posted April 10, 2006 Does anyone know if there is a difference between the XX 2002 and 2003 oil filters. Looking at Fram oil filters book only shows up to 2002. Quote Link to comment Share on other sites More sharing options...
chaserkeywest Posted April 10, 2006 Share Posted April 10, 2006 Does anyone know if there is a difference between the XX 2002 and 2003 oil filters. Looking at Fram oil filters book only shows up to 2002. Same Quote Link to comment Share on other sites More sharing options...
Furbird Posted April 10, 2006 Share Posted April 10, 2006 Same. But don't buy Fram. Worst oil filter on the market. Find the cheat sheet that tells you what car filters fit your car, and go with a Purolator PurOne (Advanced) or a WIX (O'reillys). Quote Link to comment Share on other sites More sharing options...
ironmike Posted April 11, 2006 Share Posted April 11, 2006 A little trivia for you... the XX and the GL1800 (GoldWing) take the same oil filter... and brake pads. Quote Link to comment Share on other sites More sharing options...
Fiona Posted April 11, 2006 Share Posted April 11, 2006 A little trivia for you... the XX and the GL1800 (GoldWing) take the same oil filter... and brake pads. Any difference in price when you order them? Quote Link to comment Share on other sites More sharing options...
firedlt Posted April 11, 2006 Share Posted April 11, 2006 The bird GL 1800, ST 1300 same filter go to Honda direct and buy 1/2 dozen to keep on the shelf Quote Link to comment Share on other sites More sharing options...
dissolvedego Posted May 23, 2006 Share Posted May 23, 2006 ok semi-related question: is it necessary to remove the lower cowling to change the filter? i'm lazy. Quote Link to comment Share on other sites More sharing options...
OttawaXX Posted May 23, 2006 Share Posted May 23, 2006 ok semi-related question: is it necessary to remove the lower cowling to change the filter? i'm lazy. Nope! I just did mine without removing any of the plastics. Quote Link to comment Share on other sites More sharing options...
GriffXX Posted May 23, 2006 Share Posted May 23, 2006 A little trivia for you... the XX and the GL1800 (GoldWing) take the same oil filter... and brake pads. That is great to know as we just bought a GL1800 a few months ago. Sure makes it easy when I need filters and pads! Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted May 23, 2006 Share Posted May 23, 2006 GL 1500 is also the same. Quote Link to comment Share on other sites More sharing options...
Tom Braithwaite Posted May 23, 2006 Share Posted May 23, 2006 ok semi-related question: is it necessary to remove the lower cowling to change the filter? i'm lazy. icon_razz.gif Some of the guys on the board that are good at reach-arounds have the technique down pat. Quote Link to comment Share on other sites More sharing options...
Northman Posted May 23, 2006 Share Posted May 23, 2006 ok semi-related question: is it necessary to remove the lower cowling to change the filter? i'm lazy. It's not a necessity, but I still remove both lowers when changing oil. It keeps everything cleaner, and makes it easier to check for leaks afterward. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted May 24, 2006 Share Posted May 24, 2006 It's not a necessity, but I still remove both lowers when changing oil. It keeps everything cleaner, and makes it easier to check for leaks afterward. Anal Retentive? Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted May 24, 2006 Share Posted May 24, 2006 No, Chris just worries that the oil filter case might be cracked after he torques it on..... Quote Link to comment Share on other sites More sharing options...
Obby Posted May 24, 2006 Share Posted May 24, 2006 I ended up buying the $8 Honda oil filter remover thingy. It's saving me 30min. an oil change by not having to remove any plastic! Quote Link to comment Share on other sites More sharing options...
GriffXX Posted May 24, 2006 Share Posted May 24, 2006 No, Chris just worries that the oil filter case might be cracked after he torques it on..... I thought that was N1k !!! Quote Link to comment Share on other sites More sharing options...
dissolvedego Posted May 26, 2006 Share Posted May 26, 2006 I ended up buying the $8 Honda oil filter remover thingy. It's saving me 30min. an oil change by not having to remove any plastic! how does that work exactly????????? i bought one too, and there isn't enough room behind the headers to even fit the socket wrench and oil filter screw. this is driving me crazy, all i want to do is change the damn oil... :icon_wall: EDIT: ok nevermind... a normal wrench seems to work just fine. Quote Link to comment Share on other sites More sharing options...
