K9XX Posted November 25, 2005 Share Posted November 25, 2005 Buy this. From Here Of course, for $40, you can have like 100 new washers from Lowes, but this is neat 8) And you don't have to juggle a hot drain plug Someone buy it and give a report. I don't wanna be the first Quote Link to comment Share on other sites More sharing options...
Byrdman Posted November 25, 2005 Share Posted November 25, 2005 I have always been leering of quick drain plugs, especially on a motorcycle. If it ever does leak oil, it ends up directly inline with the rear tire............... Quote Link to comment Share on other sites More sharing options...
K9XX Posted November 25, 2005 Author Share Posted November 25, 2005 Safety Nazi! Where's the fun in a dry tire?? Quote Link to comment Share on other sites More sharing options...
TechnoGecko Posted November 25, 2005 Share Posted November 25, 2005 I can vouch for how much fun brake fluid on a rear tire is! :shock: Quote Link to comment Share on other sites More sharing options...
ekasXX Posted November 26, 2005 Share Posted November 26, 2005 When I had airplanes, we put quick drain plugs on all of them and never had any problems. I would think if they were safe for an airplane they should be ok for bike. They worked great too. You buy it and let me know. or get Faingold to buy it, he has too much money anyway. Quote Link to comment Share on other sites More sharing options...
SD Marc Posted November 28, 2005 Share Posted November 28, 2005 I have one on my truck and haven't had any problems or compaints yet. Quote Link to comment Share on other sites More sharing options...
HERBXX Posted November 28, 2005 Share Posted November 28, 2005 I'm kind of curious how you could get all of the oil an XX with them as the drain hole is horrizontal and the device would take up at least some space in the bottom of the hole . Any ideas ? Quote Link to comment Share on other sites More sharing options...
K9XX Posted November 28, 2005 Author Share Posted November 28, 2005 I'm kind of curious how you could get all of the oil an XX with them as the drain hole is horrizontal and the device would take up at least some space in the bottom of the hole .Any ideas ? It looks like nothing is impeeding the flow in this cross section pic: Quote Link to comment Share on other sites More sharing options...
Steve Posted November 28, 2005 Share Posted November 28, 2005 They make a special one for Harley's?!?!?! Seems silly to me as I've always seen them simply leaving their oil everywhere anyway. Was there ever a problem with getting oil OUT of one of them? Quote Link to comment Share on other sites More sharing options...
bartonmd Posted November 28, 2005 Share Posted November 28, 2005 I'm kind of curious how you could get all of the oil an XX with them as the drain hole is horrizontal and the device would take up at least some space in the bottom of the hole .Any ideas ? It looks like nothing is impeeding the flow in this cross section pic: Herb is correct... The view they show is vertical, but the 'bird is horizontal... In effect, you'd be adding about 1/8" to the lowest point that you could get oil out of... So, theoretically, there could be 1/8" of oil you couldn't get out of the oil pan... Mike Quote Link to comment Share on other sites More sharing options...
K9XX Posted November 28, 2005 Author Share Posted November 28, 2005 Herb is correct... The view they show is vertical, but the 'bird is horizontal... In effect, you'd be adding about 1/8" to the lowest point that you could get oil out of... So, theoretically, there could be 1/8" of oil you couldn't get out of the oil pan...Mike Talk about splitting feckin hairs here....wow :shock: You know, I put the plug in as soon as it stops streaming, I don't leave it out to drain every last drop. I know, I'm a bad dad 1/8th inch huh? That's gotta be like 3 quarts :poke: I also only put in 4 quarts at the change. Not 4.1, not 4.2, just 4. I think only engineers have a problem with that small amount Quote Link to comment Share on other sites More sharing options...
willxx23 Posted November 29, 2005 Share Posted November 29, 2005 1/8th inch huh? ....... :poke: When thats all ya got thats alot. :wink: Hung Quote Link to comment Share on other sites More sharing options...
99Birdman Posted November 29, 2005 Share Posted November 29, 2005 You know, I put the plug in as soon as it stops streaming, I don't leave it out to drain every last drop. I know, I'm a bad dad 1/8th inch huh? That's gotta be like 3 quarts :poke: I also only put in 4 quarts at the change. Not 4.1, not 4.2, just 4. I think only engineers have a problem with that small amount FWIW, I let mine sit until it completely cools and then some. It has stopped dripping oil completely before I put the plug back --- and it still only takes 4 qts. (not 4.1 or 4.2) Quote Link to comment Share on other sites More sharing options...
