ekasXX
0 NeutralAbout ekasXX
- Birthday 10/28/1968
Other Bikes
No other bikes needed.
Website URL
http://placer.ca.gov/sheriff
ICQ
Roseville, CA (Formerly Lake Tahoe)
Interests
Girls / Bikes / Money
2,096 profile views
Migs..I still love those pipes. Would it be wrong to spend my family summer vacation money to get a second bird? This bike is so worth the money with those wheels and all the extras. You will regret it, unless you have another bird on the hook. This bike sold me when you let me ride it before I got mine.
Here is the link we used. The is no way in Hell HDXX would be able to figure out how to post a link. We basically followed how to find the problem area and then used contact cleaner and a toothbrush to clean off all the green and white corrosion (sp) under the brown plastic coupler piece. Then we used the silicone spray to help stop the corrosion. We flipped the cap so that water would run out of it and not get trapped inside of it and then taped the crap out of it to the loom. Scott's connection/connectors/jumpers were all green and white, so it seems the link is correct in the diagnosis. So far, HDXX's light has stayed off, so the fix seems to have worked. Linky: http://www.bikersoracle.com/blackbird/foru...ead.php?t=16438 Hope it helps someone in need.
I'm not a mechanic, but I'd ride it and put some miles on it. Maybe run some Seafoam through the fuel tank, and after a few hundred miles check it out. If it isn't a big problem, why go through the effort. Its not like the bike is a real performer anyway, so how badly underpowered from stock could it be in its current condition. Again, I'm not a mechanic, but that's what I'd do. In aviation we'd use mineral oil to help the engine break in and seat the rings, maybe someone has some thoughts on this.
No expert here, but from my experience it is VERY difficult to tweak a swingarm. I'd suspect something else if it is tracking funny since the crash happened at the front of the bike. I also agree that misaligning the axle is a bad idea. It might mask one problem and create a few more.
I used the Mity Vac to suck out all the old based on the directions in the book. I put in new fluid and and sucked it through. Once it seemed like I had fluid at all the points in the order that the book called for, I went back and did them again just to be sure. For the clutch, I got lazy and did the pump the fluid out just before empty, and started adding new fluid. I did this until I had nothing but clear fluid at the bottom. That seemed to be a good option. It has good pressure and seems to work just fine. I guess the verdict is that I should be OK and nothing should mysteriously show up and be brakeless at the wrong time. Thanks everyone, I feel better now.
I squeaked out 7K on my last Power front. I'm a "B" rider though.
OK, this is probably a very dumb question, but here it goes anyway. I changed the brake fluids and clutch fluid in my bike today. I had a heck of time getting it to get pressure, but finally used some of the posts here (instead of the book) to get them working. I went on a test ride and the new wave rotors and fluid were unbelievable. I stopped on a dime and everything seemed to be great. I figure I must have got it all done correctly. Is there a possibility that air can hide in the line somewhere and I may just be riding sometime soon and have no breaks? I think I'm good, but a little reassurance from a second opinion would be good. It works great, but just a little nervous since this was my first time doing this. Is there anything to follow up on or should I just ride?
I don't think it is normal. Mine doesn't do it and the others that I have ridden don't seem to do it either. I'd replace the pads, don't rely on visually inspecting them on the bike, the left side will have uneven wear that you can really only see with the wheel off. If you get the wheel off, then check the balance if you haven't had it done. I had a bike before, a ninja, that had a tire out of balance that caused vibrations when braking. Once I got a new tire and balance, the problem was solved. Maybe start with the two easy things first, pads and balance, then if it doesn't solve the problem, get a nice set of wave rotors. I'm not a mechanic, but thats probably what I'd do. IMO
If you got a good deal lined up on a carbed model, then get it. I know a couple guys here locally that have the carbed models and they don't have problems. There are a couple of us with the FI models, and no problems either. If you get a good deal on an FI model, then get it. If the better deal is with a carbed model, I'd go that way. Either way, you will be happy. Both are great running bikes and very smooth.
My 99 doesn't have such a sound. I've ridden both 97's and 99's, and they seem to be the same as far as any transmisson sounds go. Maybe there is something different from the newer models, that I don't know.
Never had that problem. Easy fix: Don't go low speed. Don't ride with low revs. $50 please.
A night ride is great now. If you did both lights, wait till they are both glowing on a back road somewhere. Wow.
I bought mine about 4 weeks ago and he still gave me the 185 price for the 4300K. He is still very good and fast on shipping. Very good product.
That is how I mounted mine too. Works really well, the lube just helped it retract a little better. It locks good and is easy to override if necessary.
I mounted mine a little differently, but I had the same problem at first. It worked and the throttle worked fine, but retracted slowly or hung up. I ended up putting a film of oil on the inside of the throttle grip to make it slippery (between the grip and the NEP lock). I did that probably 4 months ago and haven't had a problem since. It works perfectly.
