DirtTorpedo Posted June 2, 2005 Share Posted June 2, 2005 Any guesses where my problem lies? Oh yeah - - I was also supposed to get my inspection sticker 2 days ago. D'oh!! Quote Link to comment Share on other sites More sharing options...
demon Posted June 2, 2005 Share Posted June 2, 2005 Probably in the front brake switch or the associated wiring. Quote Link to comment Share on other sites More sharing options...
rickrad Posted June 2, 2005 Share Posted June 2, 2005 Brake light works for rear, not for front There is no front brake lights on the Blackbird. Unless you have one of those Canadian ones then I don't have a clue aboooot those, those fuckers up there are bass-ackwards so I suppose they might. :? Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted June 2, 2005 Share Posted June 2, 2005 Had the same problem with a older bike I had. Take the switch out of the front brake location the switch should be able to be taken apart. You should be able to short(if I remember right)the two poles of the switch it to turn on the brake light, if that works clean up the switch and test it. Quote Link to comment Share on other sites More sharing options...
azxx Posted June 3, 2005 Share Posted June 3, 2005 Had the same problem with a older bike I had. Take the switch out of the front brake location the switch should be able to be taken apart. You should be able to short(if I remember right)the two poles of the switch it to turn on the brake light, if that works clean up the switch and test it. What he said, the switches come apart the points get dirty in them. Quote Link to comment Share on other sites More sharing options...
Mikey Posted June 3, 2005 Share Posted June 3, 2005 If that doesn't work, follow the wire back until you get to a connection. Open it, clean it and plug it back in. Might have some oxidation. Those microswitch wear though, so it might be your problem. Quote Link to comment Share on other sites More sharing options...
bajjer9 Posted June 3, 2005 Share Posted June 3, 2005 I had the same problem back in January...pulled the switch off and cleaned it worked it several times and when I put it back on it was fine Quote Link to comment Share on other sites More sharing options...
DirtTorpedo Posted June 4, 2005 Author Share Posted June 4, 2005 It turns out one of the quick disconnect leads going from the brake lever into that starter/kill-switch assembly was loose. Thanks for the tips. Now if I can just get to the inspection station before I'm caught. . . Ted Quote Link to comment Share on other sites More sharing options...
