Tjvulvula Posted February 8, 2005 Share Posted February 8, 2005 Any recommendations for which type of adhesive to use when installing new grips? Thanks. Quote Link to comment Share on other sites More sharing options...
nickc2s Posted February 8, 2005 Share Posted February 8, 2005 Hairspray Quote Link to comment Share on other sites More sharing options...
matey_peeps Posted February 8, 2005 Share Posted February 8, 2005 There are commercially available products, which work fine, and then there's the products you probably have laying around the house. Hairspray Brake Cleaner Rubbing Alcohol Gasoline Contact Cleaner Liquid Electrical Tape Spray/coat the inside of the grips with whatever you choose to use, then, working quickly, slide the grips into place before the liquid evaporates or has a chance to get tacky. Let dry for a couple hours or overnight if it's cold. Viola, grips stuck in place. Quote Link to comment Share on other sites More sharing options...
voodooxx Posted February 8, 2005 Share Posted February 8, 2005 go to your local bike/atv shop. if you ask they probably have a display with mini tubes of the grip glue. just enough to do 1 or 2 sets of grips. costs only a buck or two. Quote Link to comment Share on other sites More sharing options...
porterb123 Posted February 8, 2005 Share Posted February 8, 2005 Use nothing. I take a small phillips screw driver and put the blade inside the grip and just rotate it around the bar as you slide the grip on...works every time. If there is no oil or grease under the grip it'll stay put with no adhesive. But I've heard hairspray does work well. PLB Quote Link to comment Share on other sites More sharing options...
jcrich Posted February 8, 2005 Share Posted February 8, 2005 The directions that came with the Pro Grip 714s said to use water, they have never moved, with the exception of using the Canyon Dancer with out something over the grip ( once) Quote Link to comment Share on other sites More sharing options...
xrated Posted February 8, 2005 Share Posted February 8, 2005 A couple of drops of dish washing liquid (you may have to ask your wife what that is) inside each grip. Don't over do it here. Makes them easy to slide on too. Let it set for 24 hrs and it's done. Quote Link to comment Share on other sites More sharing options...
JB4XX Posted February 9, 2005 Share Posted February 9, 2005 Make sure the harspray your wide uses does not contain styling gel :oops: Cleaned them out two days later and used generic Aquanet...works great and makes for a fun flamethrower! :twisted: Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted February 9, 2005 Share Posted February 9, 2005 Brake cleaner or contact cleaner. Work the red tube up between the bar and grip,spray, work up higher,spray, start twisting and old grip comes right off. Clean off ALL old adhesive on bars, shoot some brake cleaner in the grip and slip on while dripping. once dry it won't move. Quote Link to comment Share on other sites More sharing options...
RodeRash Posted February 9, 2005 Share Posted February 9, 2005 Cleaned them out two days later and used generic Aquanet...works great and makes for a fun flamethrower! Aquanet in the purple can also works great in potato cannons!! Quote Link to comment Share on other sites More sharing options...
