N1K Posted December 31, 2004 Share Posted December 31, 2004 Noticed my rotors were getting gouged by the pads. (I guess rears only get 93,000 miles :???: ) What do I have to do to pull this brake shoe off? The first picture is the view with the tire off looking from the outside.. The second pic is the view looking from under the truck out. I already have the pads and rotors. I just need to know how to get the shoe off I don't want to pull the wrong bolt and end up needing to bleed the lines etc. I have another picture if this one doesn't show enough. Anyone know? Thanks! Quote Link to comment Share on other sites More sharing options...
K9XX Posted December 31, 2004 Share Posted December 31, 2004 These two here: Just hang the caliper up with some tie-wire or bungie or something. If you let it just hang there, you could damage the line and cause it to leak. Pads come right out, then use a C-clamp to push the piston back in nice and slow. Install new pads, and you're done! I'd recommend getting the rotors turned, especially with visible damage like that. Quote Link to comment Share on other sites More sharing options...
N1K Posted December 31, 2004 Author Share Posted December 31, 2004 AWESOME... I thought so... Thanks Sean! I'd recommend getting the rotors turned, especially with visible damage like that. I already bought new rotors... The inside is gouged pretty bad. I could probably have them machined... but they are only $60 a piece. Thanks Bro!!! (hopefully the rotors come off without too much of a fight) (hello sledge hammer) Quote Link to comment Share on other sites More sharing options...
SwampNut Posted December 31, 2004 Share Posted December 31, 2004 I've got the special socket needed for removing the wheel bearing nut... Quote Link to comment Share on other sites More sharing options...
N1K Posted December 31, 2004 Author Share Posted December 31, 2004 I've got the special socket needed for removing the wheel bearing nut... My rotors are floating... Once the tire comes off, they come right off (after you break the rust-bond) Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted December 31, 2004 Share Posted December 31, 2004 I just need to know how to get the shoe off I don't want to pull the wrong bolt and end up needing to bleed the lines etc. That is why I always buy a manual for any vehicle that I own. Quote Link to comment Share on other sites More sharing options...
N1K Posted January 1, 2005 Author Share Posted January 1, 2005 Good idea.... For 50-100 bucks or whatever it is, I'm sure its well worth it. Quote Link to comment Share on other sites More sharing options...
K9XX Posted January 1, 2005 Share Posted January 1, 2005 Found this one on CD. You can print up the page you need for whatever project you are on if you don't have a greasy laptop :grin: $1.99 plus $2 shipping aint bad http://cgi.ebay.com/ebaymotors/ws/eBayISAP...7944854584&rd=1 Quote Link to comment Share on other sites More sharing options...
