RickXX Posted May 14, 2003 Share Posted May 14, 2003 While doing a routine check on the brakes I noticed that one pad on the left front brakes was totally worned out. A little more and the rotor would have taken a hit. What's strange is that all the front pads were 1/2 worned for the exception of one pad. That pad was also not worned equally. It was kind of worned into a slope. I think that Warchild had posted some picture of this. Has anyone experienced this? Could this be due to the linked brakes? It is as if more pressure was applied on one side of it. The XX has 17 Kms on it . :roll: Rick Quote Link to comment Share on other sites More sharing options...
Redbird Posted May 15, 2003 Share Posted May 15, 2003 That's "normal" for this bike. Most blame the linked brakes. The left caliper moves when you activate the front brake, causing the uneven wear (that's the popular theory, anyway). Nothing to worry about. Quote Link to comment Share on other sites More sharing options...
XXTi Posted May 15, 2003 Share Posted May 15, 2003 Several of us have had the same experience. The left outside pad was down to the metal on my bike and the other pads had half their life remaining. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted May 15, 2003 Share Posted May 15, 2003 Strange that it doesn't always happen though. I've never seen it personally in fact. It may be a corrosion issue causing the pads to hang. Are the "victims" in more humid climates maybe? Quote Link to comment Share on other sites More sharing options...
Grey_XX Posted May 15, 2003 Share Posted May 15, 2003 I've had the same symptoms (except that the other pads went within 2-3 kmiles) Hugo Quote Link to comment Share on other sites More sharing options...
Warchild Posted May 15, 2003 Share Posted May 15, 2003 Yes, sadly, it is quite common on this bike. Some of our more frugal forum members have resorted to swapping out with the other caliper to gain brakepad life (as a set). Your pads undoubtedly looked like the ones in this thread, didn't they: http://www.cbr1100xx.org/forum/viewtopic.php?t=893 Are the "victims" in more humid climates maybe? The High Desert of eastern Washington is as dry as your place; not a speck of corrosion to be had on the bike, anywhere. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted May 15, 2003 Share Posted May 15, 2003 I was just doing some work on one of the guys' bike. His pads looked completely even so far. I checked mine with 10k on them; perfectly even. I think I figured out what happened though. As everyone knows, Blackbird riders are endowed with freakishly large penises. Well, I assume the rest of you are also, like myself. Anybody going to claim otherwise? Well anyway, I make sure to "dress left" one day and alternate to the right the next. Thus keeping my tire and brake pad wear even. If you're hanging that thing off one side every day, I bet the inertia is pulling the bike to that side and wearing the pads faster. Just a thought. Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted May 15, 2003 Share Posted May 15, 2003 Yes to combat the crown of the road I dress left all the time so bike tracks straight. Then I rotate my pads to even wear. Quote Link to comment Share on other sites More sharing options...
RickXX Posted May 15, 2003 Author Share Posted May 15, 2003 Carlos, it's supposed to be aiming up and therefore creating this balance feel Rick :wink: Quote Link to comment Share on other sites More sharing options...
RickXX Posted May 15, 2003 Author Share Posted May 15, 2003 Warchild, that's exactly how the OEM pads looked. Wonder if the EBC HH pads will do the same or not but at least the pad midlife swapping can surely help. Rick Quote Link to comment Share on other sites More sharing options...
xrated Posted May 15, 2003 Share Posted May 15, 2003 Carlos, Nice Theory!.....with one exception. What about Raddragon (sp). :shock: Quote Link to comment Share on other sites More sharing options...
