ncblkbrd1100xx Posted July 22, 2004 Share Posted July 22, 2004 Has anybody came up with a good replacement for those damned plastic fasteners that seems to hold the plastic together. TIA, d Quote Link to comment Share on other sites More sharing options...
Hurricane Posted July 22, 2004 Share Posted July 22, 2004 Yeah. That's a good question. They always seem to break underneath the lower fairing... under the exhaust header collector. Think I remember seeing something similar in the help section @ Pepboys. Quote Link to comment Share on other sites More sharing options...
XX Posted July 22, 2004 Share Posted July 22, 2004 check out Lowe's if you have one around town. fitty sense or less a piece and don't break easy! Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted July 22, 2004 Share Posted July 22, 2004 I have broken a couple on the bottom.. I was planning on just getting alittle nut and bolt to take their place... just don't superman tighten it and breck the plastics :grin: Quote Link to comment Share on other sites More sharing options...
Redbird Posted July 22, 2004 Share Posted July 22, 2004 I've replaced the two lowermost ones, the ones below the header, with those little nylon license plate "bolts". I get 'em nice and snug by hand and they stay put just fine, and I've had no problems with any melting. That was a concern at first, with them being that close to the exhaust, but they've been fine for thousands of miles now. Quote Link to comment Share on other sites More sharing options...
demon Posted July 22, 2004 Share Posted July 22, 2004 I've put regular bolts under the header. thinking about getting some titanium bolts so when I scrape I'll put out white sparks. Quote Link to comment Share on other sites More sharing options...
Mr.XX Posted July 23, 2004 Share Posted July 23, 2004 I used a black zip tie thru the two holes works great :cool: Quote Link to comment Share on other sites More sharing options...
waytooslow Posted July 23, 2004 Share Posted July 23, 2004 I used a black zip tie thru the two holesworks great :cool: Exactly but I use a red one way Quote Link to comment Share on other sites More sharing options...
Northman Posted July 24, 2004 Share Posted July 24, 2004 Can I use a blue one? :wink: Quote Link to comment Share on other sites More sharing options...
R1dR3d Posted August 10, 2004 Share Posted August 10, 2004 I'll see your zip ties and raise you a $2.49 a box (of 15) 5/16 'nylon rivets' from the local chain automotive parts store. Quote Link to comment Share on other sites More sharing options...
kg4fku Posted August 10, 2004 Share Posted August 10, 2004 there is a place down in florida that sells them by the bag. John knows them and lives close to there. Quote Link to comment Share on other sites More sharing options...
John01XX Posted August 11, 2004 Share Posted August 11, 2004 Chuck is right, www.hondadirectline.com sells OEM push pins by the bag for a couple bucks Quote Link to comment Share on other sites More sharing options...
Brian03XX Posted August 24, 2004 Share Posted August 24, 2004 The 5/16 nylon rivets work the best. I had a few missing push-pin so I got some. They work better than the stock!! Make a tighter fit, the down side is that you cant just pop them. Quote Link to comment Share on other sites More sharing options...
