It ships with the zero map installed as that's embedded.
Did you disconnect the battery when installing the pc ?
Be sure it's plugged in all the way, they can be tough sometimes, and make sure it isn't in there backwards...I know that was an issue with older ones.
If you are getting nothing you either have a bad connection, the unit needs resetting, or it is a bad PC.
