K-TOOL Posted May 28, 2004 Share Posted May 28, 2004 Excuse my ignorance :headscratch: , but I am not quite sure what kind of spacers you guys are talking about. Are these just regular washers? I havent really gotten in there and looked but where are they installed. Is this an easy procedure. A buddy w/ a bird and I both want to try this mod. Thanks for the help Quote Link to comment Share on other sites More sharing options...
BIG BOY Posted May 28, 2004 Share Posted May 28, 2004 If you're talking about for the rear shock, you can use regular washers, but you can't go too big. Quote Link to comment Share on other sites More sharing options...
Northman Posted May 28, 2004 Share Posted May 28, 2004 You can use 3/8" SAE washers, about 3 thick, or body shims to get you 6mm of spacing (at least that's what I use, and it makes a huge difference, IMO). If you just go with washers, you'll need to remove the upper shock mount to install them, but if you go with the body shims (square shaped with a slot cut into them), all you need to do is loosen the upper nut enough to slip them in, then re-tighten. Quote Link to comment Share on other sites More sharing options...
Mykl Posted May 28, 2004 Share Posted May 28, 2004 What's the benefit? Quicker handling? Quote Link to comment Share on other sites More sharing options...
Northman Posted May 28, 2004 Share Posted May 28, 2004 Yes. It feels like the bike just lost 40lbs. Honestly. Go too much, and you'll lose stability, but the bike really wakes up with the 6mm spacer. Quote Link to comment Share on other sites More sharing options...
demon Posted May 28, 2004 Share Posted May 28, 2004 The bike handles better because of reduced rake and trail in the front when you raise the rear. Another benifit of this is that you increase your cornering clearance when at full lean in a turn. Quote Link to comment Share on other sites More sharing options...
Mykl Posted May 28, 2004 Share Posted May 28, 2004 Yes, I will find a 6mm spacer... I've never removed/swapped/unbolted a shock before. I take it I have to unweight it, right? What's the best method for doing this? Quote Link to comment Share on other sites More sharing options...
demon Posted May 28, 2004 Share Posted May 28, 2004 :roll: centerstand and some way of getting some compression in your front forks to get enough clearance to get the upper shock bolt all the way out. When I did it, I slotted the washers enough to slip on the bolt by just loosening it. The washers looked like a C. Basically made my own c shaped shimms where I wouldn't have to remove the shock at all. Just loosen it enough to put the ground off washers in and tighten it back up. If you do make your own shimms, don't go wild with the grinder. Just cut enough to where the center opening goes straight out the side. Quote Link to comment Share on other sites More sharing options...
Mykl Posted May 28, 2004 Share Posted May 28, 2004 Damn I'm a dumbass... I forgot the XX has a centerstand. I'm still used to not having one. Quote Link to comment Share on other sites More sharing options...
demon Posted May 28, 2004 Share Posted May 28, 2004 I have a centerstand for mine but it is not on it. The only time I put my bird up on the denterstand is when I work on it. My lower link and single exhaust make it impossible to keep my centerstand on the bike. Plus, without dual pipes, the leg sticking up for the stand kind of looks funny all by itself sticking out. Quote Link to comment Share on other sites More sharing options...
K-TOOL Posted May 28, 2004 Author Share Posted May 28, 2004 Great info guys. It doesnt sound to tough. Hopefully get it done in the next couple of weeks. Thanks for the great info. Quote Link to comment Share on other sites More sharing options...
MiDNiTXX Posted May 28, 2004 Share Posted May 28, 2004 I used washers but I cut a slot in them cause I'm too lazy to remove that long ass bolt Quote Link to comment Share on other sites More sharing options...
gcp Posted May 28, 2004 Share Posted May 28, 2004 demon guided me through this mod and it took me all of 30 minutes to cut slots into 2 washers (dremel tool works well here) loosen the rear of the gas tank and elevate, loosen the shock nut, slip into place the washers and retighten. You will like the new feel of your BB, I promise. Quote Link to comment Share on other sites More sharing options...
aptyp Posted May 28, 2004 Share Posted May 28, 2004 I'm not sure where to look it up what is the torque of the shock bolt when putting everything back together? Quote Link to comment Share on other sites More sharing options...
MaXX Posted May 28, 2004 Share Posted May 28, 2004 I just slotted some washers....I love when folks don't read everyone's posts. BTW, I did mine 3 years ago with the slotted washers, no movement, they have never come out. MaXX Quote Link to comment Share on other sites More sharing options...
TOXXIC Posted May 30, 2004 Share Posted May 30, 2004 I used starter shims. Quote Link to comment Share on other sites More sharing options...
