nickc2s
Everything posted by nickc2s
  1. To Traxxion went a used 900RR shock for a new spring. They got it at 10 am from UPS, called to clarify my request and offer suggestions. It was shipped back to me the same day they got it. Great turnaround, helpful staff and they got the spring weight spot-on, a 950 lb spring for a 150 lb rider. What a difference in smoothness of the ride. Money well spent.
  2. On the change to a 900RR rear shock, the too weak spring on the RR unit is replaced with a stronger spring. Is it possible to use the spring from the XX shock that is being replaced, or is the stock spring part of the reason for shock replacement?
  3. Service Honda had to me in 1 week 3 of 4 parts for a '65 Trail 90. They called the day after the order was placed to tell me the 4th part is discontinued. 30% off of list price too. Servicehonda.com 800 828 5498.
  4. nickc2s
    Polishing.
    Met-all.com is another aircraft aluminum polish, works extremely well.
  5. Met-all.com
  6. nickc2s
    Spa Questions
    Gonna modify your avatar so the pooch has a snorkel?
  7. You could line the plastic with Plumbers heat shield used to prevent burns to anything close to the torch. It has the same look and feel as fiberglass mat and is about 12- 15 dollars for a 10x12 sheet.
  8. You could post on Maximum-Suzuki.com , a very knowledgeable group on Bandits and Katanas.
  9. Sizing seems good, however, make sure the jeans you order will fit over boots. Their regular jeans did not. To their credit they made good on the exchange.
  10. If the '00 is the same as the '03, then the plug-in is on the left side under the gas tank just above the gearbox in a bell-shaped rubber cover that houses electrical connectors and is suspended on the wiring harness zip-tied to the left frame. Remove the two rear tank bolts and shim the rear of the tank up three inches or so. You can then see/access from either side with a light. Download the speedohealer user's manual to calibrate it.
  11. nickc2s
    Speedo recal.
    Speedohealer.com has a calculator on their site to enter new parameters that change the speedo and/or odo readings. For the bird, with a 16 front sprocket and 5.5% factory compensation, it says 11.8% difference.
  12. Never used nitro Klotz, but the Klotz octane booster spilled on the old VFR tank and stained it instantly/permanently. Wanna see my new funnel?
  13. cbrbearing.com should have them.
  14. Saw PCIII for $239 for 02 and 03 XX when ordering a SpeedoHealer from Calsportbike.com. Also ordered a t-shirt from them says: I thought you could ride.
  15. Take your tricky measuring device and measure a piece of newspaper, should be 3 thousands. That will improve your feel on the adjustment.
  16. nickc2s
    Oil Leak
    I found an oil leak from the gearshift spindle seal on the Bird today, an '03 w/ 1900 miles. Anyone else have an issue with this seal? TIA any input, Steve
  17. Color-Rite.com, 800-358 1882 specializes in M/C touch-up paint.
  18. Cal, I use the 3M on the clearcoat for the Porsche and it works. A very mild abrasive that you must wax after polishing. Check out carcareonline for product info and instructions. Steve
