Everything posted by Furbird
Get the double din. If you're going to start adding amps, subs, replacing door speakers, then you need to brand shop but it sounds like that's not a big deal to you. They do make harnesses that are pre-wired direct fit from your truck to whatever radio you buy, but it's usually limited to larger brands (Pioneer, Sony, Kenwood, etc.) It's not difficult if you don't get a pre-fab adapter, because if you get the wiring plug that fits your factory wiring and an aftermarket radio they are usually color-to-color matched as most companies are pretty standardized when it comes to that. Most double din radios come with the brackets to fit popular vehicles, which your truck definitely falls in that category. I personally would recommend Pioneer and Metra installation products, as I did 12 volt installs as a professional for 9 years. The only thing I have that doesn't have a Pioneer in it is my 2500hd and that's because the PO already replaced the radio with one with USB-in and bluetooth.
Good move. I ordered a set for my HD right after I bought the enclosed car hauler. In non-extended mode I can just barely see the sides to back it through the gate without having to get out and telescope them in. Extended I have plenty of rear view.
My KZ was so low it didn't even have a kickstand, you just leaned it slightly to the right and it sat on the header. The sucky part of that was the 3 closest tracks were all right turn exit roads so it made for some wide radius and very slow turn-offs on the big end. But we all had them so everybody was in the same boat. It's funny when a slingshot dragster has a tighter turning radius than a 7 foot long motorcycle.
Best Buy usually has a remote start car alarm on sale installed for $300 or so. Then your truck can be locked, unlocked, starts and warms up, and if you don't want the false alarm problems just tell them to not install the shock sensor so it only goes off if the door is opened. Cheapest option is a weatherproof switch like would be on a boat and you hide it in a fenderwell or possibly drill into the base of the door mirror and install it in that. I've seen that done before also.
Meanwhile in Alabama, we have KZ1000's riding around with Vance and Hines Sidewinders with no baffle. The Furbird (race bike) has a D&D full system with their exhaust from hell or whatever they called it which is a straight pipe. It is ungodly loud but at the track if you can't see me coming, you can damn sure hear me!
Dual slip-ons still saves a ton of weight (those stock mufflers are HEAVY) but a full system is so much lighter. Function before style, that's why we don't ride Harleys (well, most of us haven't gone to the dark side!) You can remove decals with heat, but I personally just catch an edge and pull them off manually. Residual glue can be cleaned up with WD40 and a terry cloth with no paint damage.
That bike says "The Flying Dutchman" on it, wonder if that's a member or former one, as that sounds familiar. As far as the stickers go, nothing an exacto knife and some time won't remove. Wheels could easily be painted back black. Why you want stock exhaust I have no clue, but you do you. That was the first thing I took off my 99 when I bought it new and put a full system on it. Changed the oil and the exhaust on the trailer after initial break-in.
Same on my 99. And I noticed it on the way to work one morning. I pulled the tank at work and we rigged the shit out of it to get it to hold until I got home. The crazy thing is the one on the drag bike, which has been pulled far, far more times and was cut to feed the wet nitrous system has never leaked.
If you have every dollar you've ever made, you haven't lived. I'm sure most of us can say "where'd all the money go" then start naming off fun times, fuck-ups, and all kinds of stories. I could be 10 times richer, but 1,000 times dumber. And lessons get more expensive as you get older so it's best to learn them whey they're cheap and you're young.
Crashed my Blackbird, need help with upper cowl!
Furbird replied to Crashedbirb's topic in The Garage
https://www.ebay.com/itm/2pcs-Snowmobile-ATV-Outboard-Jet-Ski-Boat-Engine-Kill-Stop-Switch-Safety-Tether/362201903844?hash=item5454ea72e4:g:wycAAOSwm3paS0vU Easy peasy lemon squeezy- 31 replies
- crash
- upper cowl
(and 1 more)
Tagged with:
https://www.bmwmtkisco.com/used/Jeep/2017-Jeep-Wrangler-542cdfde0a0d0cc71a38a4b43c16d08f.htm That's not a lot of markup relatively speaking.
Stock (ish) bikes are usually exempted from most of the rules on a test and tune or street-only night. All of the tracks I've gone to are basically full leathers, gloves over the wrist, boots over the ankles, and a DOT full-face helmet that you must keep the visor down on. The only mod I had to have on my drag bird was a lanyard shut down switch. I used one from a jetski and wired it in tandem with the run/off switch on the handlebars. It attaches with a clip to the zipper on my left sleeve.- 31 replies
- crash
- upper cowl
(and 1 more)
Tagged with:
High end of trade-in value and a check in your hand instead of numbers on a trade-in sheet that they can manipulate. Sweet!
I'm guessing (hoping, praying) that somebody took the pick-up tubes out of those bottles before filling them. When inverted like that they need to have the tubes removed if you didn't know. The stock engine can handle at least 2.5 times that amount of nitrous, but good luck keeping the nose down.- 31 replies
- crash
- upper cowl
(and 1 more)
Tagged with:
You can probably smooth out the cuts on those ram air tubes as nobody will ever see it and they don't fit perfectly even from the factory. Headlight, cowl, front fender, check the forks, might need the stay might not, just have to check for straightness. Check on ebay or the for sale section to see if anybody has that stuff. Cowl shipping is a big friggin box so shipping will be high.- 31 replies
- crash
- upper cowl
(and 1 more)
Tagged with:
See box 9 for the 97-98 models in this link. 9 doesn't show up as applicable for the 99-up. https://www.ronayers.com/oemparts/a/hon/506c1f98f870023420a2f4b7/upper-cowl- 31 replies
- crash
- upper cowl
(and 1 more)
Tagged with:
If you're talking about #9 in this image, that does not apply to FI bikes, it is carb only. FI bikes don't have the mesh in the front as the ram air tubes run directly into the airbox. https://www.ronayers.com/oemparts/a/hon/506c1fe6f870023420a2f5b5/upper-cowl- 31 replies
- 1
- crash
- upper cowl
(and 1 more)
Tagged with:
$39 shipped on ebay brand new. If they do it like AT&T does, they can reprogram the SIM it comes with for no additional charge. Why you want a flip I have no idea. I personally have a candy bar (straight) phone. You can't kill it. Flips break at the hinge. But here you go. https://www.ebay.com/itm/Prepaid-Verizon-E-Talk-Flip-Phone-4G-LTE-2-8-OVGM-dislpay-2-MP-camera-1500-mAh/283646400089?hash=item420aa49659%3Ag%3AZoYAAOSw5nBdqKcV&LH_BIN=1
I was kidding. But also didn't know I'd start a bidding war. So when the nukes go off it will be Carlos' fault since he added in the Vroom one. I was pitting KBB against Carmax but now it's like the Batmobile at Barrett Jackson. I am running low on Reese's cups though so there's that... 🤣
See, it's like ebay but you actually get paid. I expect my bird dog fee 😁
Those guys are going to shit a brick. They don't even have to detail it. I've only ever known one other person as anal (not the board kind, but attention to detail LOL) as you. Older ex-military guy that ordered Firebirds and the dealer would call him on delivery day so he could supervise them rolling it off the truck. They wouldn't even PDI it unless he was there. He pulled all the plastic off of it and did the first detail with Zaino products before he even signed the paperwork.
I feel your pain, legitimately. Now I have a climate controlled shop with a lift and hydraulic jacks because I'm too old for that shit.
KBB.com offers an instant cash deal where you fill in all the pertinent information (and it is pretty detailed) and they will email you a legit offer for it. Trade in shows 22-25k even deducting for the no AC option and that's in my zip code so it should be higher in an area where AC is not basically mandatory. It may be worth attempting to see if you can get what you want out of it. I would also take it to Carmax so that way you'll have some hard numbers to look at to see if it's worth keeping or not. No sense in giving it away if you have firm offers for more money and allowing somebody else to flip it at your loss. If you really don't want it going to a dealer you could stick it on ebay with a buy it now close to what your kbb and carmax offers are.
I guess the 24k offer guy didn't show up? Why not trade it in, or are they raping you with an offer? What about Carmax or whoever it is that gives you a cash offer on the spot?
Speaking of this thread, did you sell the Jeep yet?
