CBR-RR-XX-CESS
Everything posted by CBR-RR-XX-CESS
  1. Thats what I was wondering since they said fits goldwings. My guess they would but you never know.
  2. Is it a carbed model? Which year? miles? Did you fill up with gas at the end of the first day(water in gas?) Dirt in carbs or water in gas would be my first guess.Then electical,loose plug wire,fouled plug,ect. JS
  3. After four years I would say its on borrowed time. Every time I pushed the life of a motorcycle battery it would fail at the worst time. I would replace it. JS
  4. New to me with good prices- http://www.dtmaonline.com
  5. Yea, what is is this white shit,more to come this weekend. Time to head to AZ and take care of Carlos for his porn escapades.
  6. Stay tuned for an indepth test. I purchased two of these,gave one to Cal and he is going to run a before and after dyno test. Expecting a .2 hp gain
  7. Well,we will see I just bought two,one for the XX and one for the 954,there is a sucker born---- JS
  8. Did not realize they were that tall, still considering a trip down that way in Nov.,will be interesting to see. Carlos would you send me a list of roads that are must do"s. Thinking I will have three to four full days to explore AZ. JS
  9. Is your forest like LA CA forest.which comming from the Northwest I had to laugh at as I was admiring their thirteen foot stature JS
  10. What was your symtom when your rod was gummed up? JS
  11. Seems I read somewhere here about the clutch actuation rod getting gummed up. My clucth on downshifts engages abruply in a two stage fashion. Wondering if anyone else has had this problem and the cure. JS
  12. Changed mine last weekend after my trip cuz it got loud enough to hear through my helmet and was bugging me. All gone now,you will know when its time unless you have a hearing problem. JS
  13. Yes I have it still,my fender really took a beating during that extended 150mph run in Cody and may replace with one that has not been sand blasted. We both are fine,you know you could drop in once in awhile,christ you been close by a number of times.Your always welcome to spend a night when passing through.Later,Jeff
  14. This might be old news since every one seems to be well informed.. Thought this was a slick lock,check out the vid. Not sure if it would work on the bird. Little spendy at 2 bills but if I did interstates I would have one. http://www.brakeawayproducts.com/#
  15. Not very long unless you change it soon I would ride easy till you do JS
  16. On both the XX and the 954 I found that a medium size pipe wrench will fit on the oil filter well enough with out taking the fairing off. On the 54 I do have to spread the fairing at the bottom alittle. Works as good as any filter wrench. Jeff
  17. But be forwarned,its possible it won't fit. I'm not the only one here who has this problem but my fender has a twist to it right from the mold and the extender rubs on one side,had to remove it in my case. How the hell are you Tim? Have not talked much with you since our last ride and Cody was real busy so we were unable to chat much. Hope all is well, Jeff
  18. Interesting mod. How long does a bottle of gas last and the cost of refills? Jeff
  19. They recommened the update for greater stability if you ride hard or do track days . Had mine updated at 6k and it did calm the front down,on the 954 anyways. I doubt if it would be an issue with the XX. Jeff
  20. This is interesting,on my cbr954 which had tapered bearings Honda has updated them back to standard roller bearings to help eliminate head shake. On the XX which is heavier this might not be a problem. Jeff
  21. CBR-RR-XX-CESS
    Tires
    [quote name=" The rear was determined to be a "test" tire' date=' that's why it wore out so fast, and also that's why Avon wanted the whole tire back not just a piece cut out of the tire with the DOT number. I have around around 500 miles on the rear and some of the nubs are still on the tire. My avon is about shot at 5k,do you have a number for me to call ? I wonder if I have a test tire,Cal would like to know two since his is shot also with like mileage. Thanks,Jeff PS Can someone tell me how to properly use the Quote feature? I"m shot today after a 450 mile ride on the 954 yesterday.
  22. CBR-RR-XX-CESS
    Tires
    Dave, I have ran BT's for years,if you are looking at long life I would advise agaist them and go with avons. On my gpz1100 which is similar to the XX best I could do is 5-6k (rear-front) Jeff
  23. CBR-RR-XX-CESS
    Tires
    Please tell me how you get 10k,I run those on the rear of my 954 and get about 3.5k.Yes I ride somewhat hard but even if I putted around I don't think I would get even 8k. Must be doing something wrong. Jeff
  24. Info in this thread---- http://www.cbr1100xx.org/forum/viewtopic.p...ght=oil+filters
