I forgot to mention I can't run a mode 6 scan. I don't know why. Perhaps its a function of the ECU flash for the CNG conversion, but it wouldn't make sense to disable any of that for CNG. Iceprick, you should see these plugs in comparison to what you just suffered through. Threaded portion is about three inches long, I swear.
Okay, I picked up that truck I yammered about in the Pub. It's a 2015 Ford F250 Superduty 6.2 gas, 4WD Supercab equipped with factory duel fuel CNG. I get the impression of an abused mule. We're not really communicating. Not too long after I got it, I noticed some jerkiness that led to a P0301 code for a misfire on cylinder 1. I drove it for a bit, thinking some fresh gas might just straighten it out. It didn't, and the miss got worse. I bought a generic coil to replace the original. A quick review might be important here. The 6.2 in this year had a dual plug head. A coil over plug has an output for a traditional type of plug wire to transfer to the second spark plug. So I changed the coil, and things seemed to be better but not perfect. Shortly before NotRacer, I took the truck out for a long shakedown run, and low and behold, under heavy load, I again was able to generate P0301 several times, and once a P0308, although once is an anomaly. My "once bitten twice shy" side rented a truck from Enterprise to haul the trailer to Florida. Not doing that crap again stuck in Nowhere In The Mountains (Actually it was on Tater Hollow near Hillesville, VA). Now I'm messing with the Ford again. I swapped the spark plug wires from cylinder 1 and cylinder 2. I had changed the coil and still got the code. So now I swap the wire. If it's the wire, it should give me a P0302. If the new coil is not good, I'll still get P0301. And I still get P0301. Then I put the number 2 coil on the number 1 cylinder. And I still get P0301. Sigh. I'm trying to research what parameters trigger the misfire code, and all I can find is a deviation of greater than 2% engine rpm between consecutive cylinder fires. So what then? I've got a single cylinder misfire that does not follow the coil or the second spark plug wire. The truck has new spark plugs. even if one was bad, the other should provide adequate combustion, it being new and all. It's intermittent, and mostly occurs before full warmup. It does it whether it is running on CNG or gasoline. Each fuel has its own injector. There's nothing that would make me think it is air delivery. Changing spark inducing parts doesn't make a difference. Again, there's no reason to consider that both fuel systems are faulty in exactly the same way. And it's intermittent, which kinda rules out a broken valve spring, low compression, or mechanical fault. Arrrgh!
From the premium site, not mine.
rockmeupto125 replied to XXitanium's topic in The Sales Floor -- For Sale/Wanted
Hank, it looked familiar, but I didn't have time to do the research on it. -
Actually, the VT reg should be enough to get you a title in most states. -
No title "due to age." Right. Even I have a birth certificate, and I'm damn near salvage. -
Entirely possible. Could just delete anything more than a year old. One thing that would deter me is that there is technical information and possibly pricing indicators for others looking to sell or buy similar items in a very specialized market.
2000 Chevrolet Silverado in Northeast PA
rockmeupto125 replied to rockmeupto125's topic in The Sales Floor -- For Sale/Wanted
Not of it getting 19 mpg I can put a couple up tomorrow of it getting 0 miles per 0 gallons. -
Absolutely correct. My error. This is a 2500 2WD. It does not have the body rise of a 2500HD, so it is easier to get in to, and cannot accomodate the larger 8.1 or duramax engine, nor the manual ZF or Allison trans. It does have the heavy duty suspension including 8 lug wheels. -
Yeah, chalk that up to one of the stupendously stupid things I've done. An extra day to spend, warm weather, an extra set of hands, and instead I head north, park the truck because it's finally leaking too much, rent a car to get Jess home and head back the next day to change a water pump in 40 degree weather. Took me about 2 hours total and I could have saved a raft of trouble. Make mistakes, they said. Get smarter, they said. Errrrrr.... -
Hey all, trying to get my life moving again. I can't maintain this fleet of vehicles. If you're in northeast US of A and are looking for a good work truck, this may be for you. Of course, I don't care where you are, but possession/delivery might take some head scratchin' if you're in Kansas. My Chevy Silverado is on the block. It's a 2500 series, 3/4 ton but it is 2WD, therefore not a 2500HD. Regular cab (2 door), 275,000 miles and has been a reliable, good running truck. It has the 6.0 liter engine, 4L80e trans and 3.73 G80 differential, which means it has a sort of positraction that kinda works. Towing package so it has heavy duty springs and rear disk brakes. It is originally from North Carolina and the frame/body are solid, but after 13 years in the north the rocker panels have rusted through and there is slight bubbling over the rear wheels. I've put 100,000 miles on it after buying it in 2011. If it wasn't a standard cab I'd never consider selling it. But here we are. Things I remember replacing include the carrier bearing, differential cover, water pump, alternator, radiator, shocks and power window motors because that's a GM thing, apparently. Obviously consumables like batteries and tires. The seats were ripped and I found some nice ones, so they got changed. The AC doesn't work. It's pulled everything I've put it in front of. Towing a large enclosed trailer at 75mph is 8mpg. I recently towed an 8500lb truck on a 2500lb open trailer from lower Virginia to northern PA and got 12 mpg at 60-65. Empty with cruise set on 55 it gets 19-21mpg, no fooling. Around town is 14.......doesn't go into overdrive until 45mph minimum. Post up or message me with any interest. Pictures available if there's interest. Asking $3000 on other venues and I always do better for forum members
Need Blackbird spare parts.
rockmeupto125 replied to rickrad's topic in The Sales Floor -- For Sale/Wanted
Cluublights, post or private message me a list of what you still need. I'm finally getting dug out here -
Sach, because of the vagaries of autocorrect in our lives, I want to clarify. NEVER adjusted valves....or NEWER adjusted valves?
Disconnect the power commander if it has one. Replace the fuel pressure regulator.
Dark mode / Themes / Style sheets
rockmeupto125 replied to Nova Scotia Mike's topic in Board Tech Issues & Help
I have no clue what I'm doing anymore. -
Has to stay open so that if a member can't access, they have a way to communicate a need for assistance. At least it's only a small place to keep tidy. -
I deleted it. No time for his crap. -
Those of you who have visited me may realize just how much XX salvage I have. What you may not realize is the weight of that endeavor. I'd like to be a big help to the XX community, which has given me so much, but it has become a significant burden to me, and I no longer feel I can participate as much as I have tried. That being said, I am divesting myself of the great majority of my XX parts stock. I am NOT including those highly sought after items that are frequently damaged in crashes. I sell those here, on ebay, and other forums, and have made enough money to continue to buy salvage XX's and distribute parts, but that is stopping now. Representative items would be any plastics, seats, tanks, instruments, mirrors, headlights, ECU's. You get the idea. So if you have a need or want for a particular XX part for rebuild, experimentation, or just replacement, shout out. Most of it is free for the cost of shipping. If I have a ready market, I'll give you a price that will be nice on your pocket. Shipping from Pennsylvania. I've thrown out 5-6 XX's in the last month. Probably 10 swingarms, and a few frames. Time to move on. Not from an XX, but from this particular service venue. Thanks for reading. Oh, I forgot to mention. None of this will happen in a hurry. As I sort through the piles for the last time, I'll look for any item requested. Not going on a search for it.
I almost did after reading that.
I'm sure I have a mirror. If you just want to replace the glass it will be from a local glass shop. Mirror comes as the enclosed reflective part with the swivel mounting arm. -
Bring your own lights. I'm sure I can find a board for people to sit on.
It's not a polished floor, just power troweled. I was looking at the PS100 sealant. No pretty colors.
