Motorcycle oil thread, because it's been too long.
superhawk996 replied to superhawk996's topic in The Garage
Black smoke upon take-off, something's making it run super rich. I was only behind it briefly so I don't know if it continued while cruising. Gen 2s seem to have a somewhat common oil consumption problem, but not to the point of visible smoke. Mine did after doing the first oil change with cheap dino oil, I don't remember how much it was eating, but it was a lot more than one could consider normal. Then I switched to synthetic and it pretty much stopped, it used about a quart every 5k miles. -
I know, but most of that was stuff I'd considered posting anyway so your question became my excuse. Besides, it gives The Professional an opportunity to tell me how stupid I am for mixing fork oil willy-nilly. -
This one has no leaks and no smoking. Shit, it might be empty. I've seen a few 'tuned' Harleys roll coal; more fuel mo powa! I saw a Prius roll coal the other day, it made me chuckle. -
No clue what the air gap is, I filled them from the bottom to approximately the factory spec...I think. Spec is 9.7 ounces, but it doesn't say if that's each or total. From forums and videos everyone says it's per side, what came out was about 9-10oz total for both. There's no sign of leakage and they still had some air pressure after being parked forever so my guess is that the last guy did 9.7oz. total. They call for 10w which I didn't have so I mixed some 5 and 20 blindly aiming for somewhere around 12. And yes, I know the number on the bottles mean nearly nothing. The left fork supposedly has to be filled from the bottom which seems harder, but in this case it's easier to fill them both from the bottom. I guesstimated spillage and added a little extra to compensate. I forgot to put the schrader back in before pulling the filler hose from the right side so it's probably a little low, but nowhere near how low it was. With the schrader in it creates an air lock so less spills out when pulling the hose to insert the screw. Smart me would have prepared better and pulled a vacuum to not spill any. -
Reading your replies helped me figure out why diesel oil is actually appropriate for them, they're monstrous engines with no horsepower. For an 800 pound couch it pulls decently, but it is a 1450cc engine. I've come around to liking some aspects of it. Being able to throw lunch/parts in the luggage makes it usable for quick errands. I like playing with the radio and cruise control. I've always hated the springiness of the forks, it was a friend's bike so I've ridden it a couple times over the last many years. After changing the fork oil they're pretty damn decent. -
So you're going to further prove what I said about Diesel engine oil running cool after stupidly arguing that they run "hot as fuck" just like a Harley...perfect. While you're waiting for those unnecessary photo opportunities, look up Harley specs on piston to cylinder clearance so you can see how wrong you were about that "generous piston to cylinder clearance" statement as well. -
You're just digging a deeper hole stupid. Of course the oil temp is higher than coolant temp, if it wasn't the engine would be fucked. That doesn't change the fact that Diesel engine oil typically runs cooler than gas engine oil. -
That shit's spendy yo! -
He's recently made some non-retarded and non-insulting posts so I thought maybe he'd have something other than the shit he posted here. -
I know diesel oil is good for bikes, I've been using it since long before the .org existed. Harley piston/cylinder clearance spec is .0009"-.0015", if that's "generous piston to cylinder clearance" I'd love to hear what motor uses tight clearance. There are tons of V-twin specific bike oils of the right viscosity so I see no good reason to suggest using a diesel oil of the wrong viscosity. Diesel engines don't run hotter than gassers; the coolant temp is about the same and EGT and oil temps are typically lower in diesels than gassers. Harley oil temps typically vary from the lower diesel temps to above gasser temps depending on conditions. I've readily admitted to being wrong and have thanked people for correcting me, you're projecting your own mentality again. -
Or maybe so they wouldn't discover that there are better bikes at half the price. -
That's some funny shit. -
Ok, then you tell me why they say to use diesel oil instead of motorcycle oil. -
I found this interesting. My Harley manual states to only use Harley oil, of course. The surprising part is that it says if you need oil and can't find Harley oil you can use Diesel engine oil to get by on. Then, obviously, you need to change it as soon as possible so that it'll be back to pure Harley oil. I was shocked that it suggests diesel oil instead of motorcycle oil. Why would Harley state diesel oil, could it be better than motorcycle spec oils? Then it hit me. I wonder if Harley only suggests the diesel oil alternative to avoid having you think about using some other brand of motorcycle oil instead of theirs. Like they're trying to convince you that those other oils are SO fuckin shitty that they're not even good enough to get you by in an emergency, but the diesel stuff that doesn't really belong in there is at least ok enough keep it alive till you can find Harley oil.
He would have wasted that time regardless, but he likely wasted the time to create a login and reply to the ad. If he noticed that it was 15 years old he was prepared for it and decided that it was worth a try. If he didn't notice, he deserves it.
Cool Microtech knife…anyone?
superhawk996 replied to racer212's topic in The Sales Floor -- For Sale/Wanted
Being an auto is one part, many states don't allow carrying a double edged knife so this has two possible illegalities in one. -
Will you drink milk from Chinese cloned super-cows?
superhawk996 replied to SwampNut's topic in Diet & health exchange
He, and many others. There's a bunch of stuff about milk that's 'bad' for us, but I don't think it's any more bad than a lot of things we normally eat and drink. -
You'd probably be in less legal trouble if caught banging a 12 year old on the playground than carrying that thing, but you'd still have the support of your friends with a felony knife charge. -
Stuff's probably safer than going down on a vaxxed chick. Cow milk is already said to be bad for you, I don't know why this stuff would be particularly dangerous. It's not like we're dealing with bubba's latest moonshine inspired brain storm, it's being done by professionals in a Chinese lab; worst case scen Have I mentioned that we should nuke China before they succeed in killing us all? -
Worst case scen -
With many bikes they have to be removed to open them and the nearly 30 year old rubber boots are probably not rubber any more. I don't buy smokes, I make them. The only store runs are for parts/supplies that often can't be reasonably or easily carried on a bike. The only friend I visit somewhat frequently is either to help with something nesessitating tools and/or to hang out on the patio which means drinking. I have left the bike there overnight before, the 'quick visits' often turn into 5 hours of working his keg and various bottles. I usually leave in reasonable condition to drive home, but often not reasonable to ride. And the biggest killer, since I don't have a covered place to park it it lives under a cover in a spot that is somewhat of a pain and often blocked by a car and/or stuff. And it has to be backed in carefully because there's little space.
I've never had issues with gas in the tank going bad. The Porsche I recently resurrected sat about 10 years and the gas was still good enough to not have issues. I drained it because it's a fucking Porsche so it got new premium, but the old gas went into the forklift and F-150.
In contrast, the fuel injected bike I just finished getting running had a seized fuel pump, broken pressure hoses, and stuck injectors. It required new parts and more work. FUCK EFI!
I forgot to say, the bowls were a lot cleaner than I expected. A tiny bit of brown sediment which is common with any carb even when they're working fine. No green shit, and no goo, just totally clogged jets. Spray cleaner wouldn't bust through, had to use a wire to poke them out.
