Everything posted by flyv65
I've only got 150 miles on my pair, but they're noticeably less "squirmy" when new: the tread isn't as deep, and they scrub in pretty frikkin' fast (maybe 25-30 miles or so). When I get rain out here I'll let you know about the silica compound and how well they stick. Bryan...they spooned on easier than the 45/46 combo...
Anyone have the quick and dirty on replacing the rear shock?
flyv65 replied to Obby's topic in The Garage
Dale about hit it spot on, but I didn't remove the tank, just lifted the rear up far enough to get some room to undo the shock kingpin nut. With the bike on the centerstand, I put a flat-bladed shovel under the rear tire and let the weight of the rear tire/suspension/swingarm fall onto the blade of the shovel, leaving the handle rising up behind. After pulling the bottom shock bolt I dis assembled the dog bones, checked the linkage and cleaned and re-lubed everything for the installation. I set up the Penske about 5mm longer top to bottom, mounted it on the kingpin, and reinstalled the kingpin inot the frame, routing the remote reservoir out the left side and strapping it onto the outside of the rear subframe inside the plastic in front of the handle for the center stand. That way, I could adjust the 6 position knob easily with the seat off without screwing with the plastic. I put the rest of the rear shock parts back on the bike, and just pressed down on the shovel handle to raise the rear tire to the height I needed to slip the lower shock bolt through the linkage-piece of cake. Torque evertything back to spec, set your sag, and hit the road. Bryan...If I can do this, anybody can... -
New canister came in at lunch, and it's an honest 2.5" ID...success is just around the corner. i'll try it out tonight and see if everything clears the swingarm, then button it up. Right now I'm scheduled for a custom map on the 16th, so I'll let youse guys know how it goes. Bryan...thanks for the help, guys...
Don't gap the new plugs: they come from the manufacturer properly gapped. Use a wire (not blade) gauge to check the gap and just put them in. If they aren't gapped correctly, take them back and bitch about it. By the way, changing plugs takes way more time than it needs to 'cuz of where they are (behind the oil cooler/radiator/lower panels/inner panels, etc.) Rumour has it you can go in through the air box easier. Check Dale's (Warchild) site for the How To write up. Bryan...I already had the radiator moved out of the way to put on the exhaust...
So *that's* what the Iraqis did with the missile tubes: made exhaust headers out of them! Those cheeky monkeys! I just want this thing mounted properly so I can get back to the important things in life: a quick ride now and again, and... . Bryan...cancelled the custom dyno map time I had reserved for tomorrow...
That's some funny shit. My bud brought his pipes up to put them on and he has Microns. The collector/can issue was the same. The collector seems HUGE and the end of the can goes right inside it with plenty of room to spare. After looking the whole thing over, we were under the assumption that Micron sent him the wrong mid pipes, but they looked just like those in the picture. Were we supposed to flare the hell out of the can to fit it on the mid, or should it fit over the mid with no modification?? If we WERE supposed to flare it severly (which doesn't seem right to me) he is gonna be PISSED. Well I just called Micron this morning and said that I thought I got the wrong canister for the 'bird: after all, you shouldn't be able to slip the canister "inside" the collector, right? The fellow I spoke with agreed with me, and after I gave him a credit card number (they'll credit it back when they get the other one in), said I'd be receiving a can from FedEx on Wednesday. I'll probably dick with the collector some tonight to get the mounting tab on the inside, and keep my fingers crossed that the canister they send me isn't the same. Bryan...thanks for the help, guys...
Yeah, every other system I've seen went "on", not "in". When I got home last night I measured the parts: the slipon is 2.25 inches, and the collector is 2.5 inches...one of them is not right for the bike, so I'm calling first thing tomorrow morning and getting *that* straightened out. One more thing bturd: the instructions say that the collector mounts on the inside of the old mounting point, but it sure doen't look like it'll fit...is that where yours mounted up? Bryan...I'm not used to having issues with shit like this and it pisses me off... :icon_wall:
Yeah, it seems like header/downpipe ! is the one I can't quite get all the way in, so I keep loosening the header bolts and I've gotten the mounting bolt through the collar-but it's fuckin' tight, my friends. I'm going to keep whacking away at it after work today. One more thing: the instructions said that the canister goes over the collector, but the one they sent slides (with room) inside the collector. Did anybody have to flare the piss out of the canister opening to get on the collector? Bryan...if it isn't one thing, it's another...
...'cuz I'm trying to put one on my bike, and I can't get the frikkin' mid pipe mounting bracket to quite get ot the mounting pont under the right foot peg. Did anybody else have this issue? Bryan...missed it by that much... :icon_banghead:
The stock rear shock is woefully undervalved and painfully oversprung: this leads to the sensation of getting your ass spanked when riding over stuff like expansion joints. If you're good with handling shock springs you can swap out the stocker for one suited to your weight and ridnig style for about $150-or you can pay a suspension shop $250 to do it. In these cases, the shock is now proper for yuor weight, but the valving is shit soft, and the ride gets unstable. As mentioned above, Ohlins makes some shit hot boingers for our bikes, but they aren't cheap. you can also check w/ Traxxion Dynamics in Woodstock, GA for other choices: I bought my Penske adjustable (8981? remote reservoir, limited adjustability) from them for about $750, but they also make a sport type Penske for around $550, if I recall. Replacing the shock will give you the best results; then do the fork springs and set up the sag properly-this will make you faster than if you added 15 horsepower to the bike. Bryan...I'm not kidding...
Yup, I do it a quarter turn at a time, myself.
'Cuz the chain adjuster is only as good as the kid who assembled it at the shop where your bike was put together-and that is one of the lowest paying positions in the service shop (learn where everything goes-then we'll tell you what it does). When I've got the axle properly snugged down, there is about 1/8th inch travel in the left adjuster and over 1/4 on the right; I suspect becausethere is too much play between the snap ring and the sliding marker. I guess that the adjuster marker is often accurate enough, but I trust my eyes alot more than a sliding marker I can wiggle back and forth on the swing-arm. YMMV. Bryan...or we could sell our Blackbirds and buy VFR800's: they have concentric self-adjusters, IIRC...
I called them yesterday AM and got a kid in service, who gave me a service ticket number and instructions on how to send it back so they could take a look at it. I'm hoping that fixing the bloody thing won't be too expensive; I sure don't want to buy a new PCIII for the bike if I've got this one available. Almost all the mods I've done to the bike have been for handling, not horsepower: Ohlins fork springs and RaceTec Comp and Rebound valves in front, Penske rear shock out back, Carrozeria wheels, the usual SSBL, heated grips, garage door opener. The only thing I'd done close to performance-wise was the K&N filter and the PCII...I wanted to level out the flat spot around 5K rpm and put in a map eventually. Now the time is "eventually", and it turns out the PCII shit itself sometime in the last two years (I bought it in Feb '02 and had it hooked up to my PC in '04, so I know it worked then). Bryan...waitin' to hear back from Dynojet on cost to repair...
Firstly, it takes some big-ass sockets (6 point, preferably) to get a hold of those nuts (heh, heh, I said "nuts"). Secondly, the rear axle torque value is 93 Nm, IIRC-which isn't exactly "finger tight"... it takes a bit of oomph to break loose. Thirdly, I have yet to see the Blackbird that has a decent set of chain adjusters on them: it seems they all wobble and float some, and you for sure can't trust the stamped marks on the swingarm. So you check the slack, put the bike on the centerstand, adjust the left side first, then adjust the right side so that when you spin the rear tire, the teeth on the rear sprocket are centered on the chain. Now you snug up the axle, and spin the wheel again to make sure the axle didn't drift while you tightened it. Bump the bike off the centerstand and check the slack. Look good? go ahead and torque the axle nut, check the slack again, then put the bike back on the centerstand and make sure the chain is still centered. I know it sounds like you're doing alot to adjust a loose chain, but once you get used to it, it's only about a 5 minute project. Bryan...don't forget-"too loose" is better than "too tight"...
Nope, we live in Stoney Brook, Between Wadsworth and Garrison, just north of Ken Caryl. We're gettin' ready to put the house on the market (Tracy wants more room, and I want a three car gargage with a south-facing driveway), but we want to stay on the southwest side of town. I doubt we'll wind up more than 4 or 5 miles away from where we are now. I need to get the house in shape to sell, but wouldn't mind meeting up soon to sniff bikes, if you want. Bryan...I hate moving, 'cuz I hate packing all my shit...
Ahhhhhh Glenwood canyon, I went 5 over through there a few weeks back (speed limit is 110 there right?).. I think I am going to stick with the Z6 rear, if I am getting 4-5k, I really can't complain. The M1 front is still looking good at this point, the rear is about to go. Plus, affordable tires up in denver has the Metzelers dirt cheap. PS .. I see your in littleton, whereabouts? I did two weeks on the Z6 tire in the Alps (I won and Edelweiss Tour-I know, lucky son-of-a-bitch, huh?), and the bloody tires wear like iron and are really pretty sticky, but I just couldn't get past the fact that they'd let go (front and rear) COMPLETELY when I rode over tar snakes...it just freaks me out. It sounds like you solved some of the problem going w/ the M1 front and Z6 rear. Tracy and I live by Wadsworth and Ken Caryl on the southwest side of town...anyplace near you? Bryan...rode in today-it's faster than taking the RTD milk run buses...
At a street pace, there is no performance difference between the Avons and the Sportec M1, save for the fact the Avons ride * a bit* harsher than the Metzlers-due, no doubt, to the higher tire pressure. Conversely, I get double the mileage out of an Avon rear that i do from the M1 (about 2500 miles verses 5000 from the Avon ST). In the wet, the Avons are great when they're new (less than 2000 mi.), at least good untill they wear out-we did triple digits through glenwood Canyon in 50 degree rain two or three springs ago. I'm currently running M1s, but that's only 'cuz I got a set from SWMotoTire for $196 shipped: when they're burned, I'm probably going back to the Avons (46 rear, 49 front). Bryan...I hear the Pilot powers are nice, but I doubt they'll get much for mileage...
I used the National Cycle flyscreen-mounted at two points on the handle bars, and stable to an indicated 146 mph. It didn't block all the wind, just took the brunt of it off of your chest so you didn't feel like you had been lifting for the last 250 miles. I'd had one ofthe big barn door fairing Plexistar II or II windscreens that was great in the winter, but hot as heel in the summer, and it limited my top speed by about 25 to 30 mph. Then again, I had a V65, and you've got the SuperMagna...they may be different. Bryan...I think they made a 4 point mount only a little bigger than the flyscreen, too...
So I took the 'bird in for a custom map this past Saturday-she'd been running pretty rich and mileage was down, but when the Dyno tech hooked her up to the computer it turns out my PCII shat itself sometime in the last year or so. Since the PCIIIusb isn't out yet for the '01 yet, I'm sending it back to Vegas to see if it's worth fixing, but I wondered if anyone else has had an issue with the PCII: I hear it's not unusual for them to crap out. Bryan...baseline top HP was 128, by the way...
Oooof:I bought a Penske rear from them about 16 months ago, and did my forks about three years ago with Ohlins springs and Race Tech C&R valves. I don't think I'm gonna jump on this one, Dale. Bryan...thanks for looking into a GB, though...
I have no been able to find any info on this.... I heard about it awhile back and I know a lot of guys have done it... anyone have a post to info about this or can give me info on what it is and what it does? Thanks. Pull the rear shock and remove the shock kingpin underthe saddle (the radiator overflow tank is attached to it, but it's only a pressure fitting, IIRC-let it hang). Take the kingpin to ACE Hardware and find what size washer fits over the kingpin. Oput on enough washers to equal 6mm of height and reassemble. The EASY Way: Take the nut to ACE and leave the rest in place. Buy the washers that fit and take them home. Cut out enough of the washer so that they look kinda like a horseshoe. Put a little bit of rubber cement on each washer, stacke them, and slide them into place *without* removing the whole kingpin (the rubber cement keeps everything in place while you put it together again). IIRC, Jaws sells a specific 'lil urethane washer cut to fit instead of using metal washers from the hardware store. Bryan...HTH...
I'm getting slightly more out of my ST 46 (about 4k to 4500 miles). Anybody else who'se run the Avons can compare the Pilot Powers to them? bought a set of Metzler M1 from SW Moto Tire last week: $!96 delivered. For that price, I'll put up with a disappearing rear tire...
So three years down the road the grips are still crankih' out the heat on high, and I didn't use an underwrap. I just put the same set up on my wife's ducati 900SS CR and they are working just fine. As far as the knock offs go, yeah, they look similar-but the prices are, too. If they *are* just re-badged DualStars then go ahead...but I ca't say for sure from the web sites. bryan...what's an extra buck or two for piece of mind?...
Hey Hugo- if wet grip wasn't an issue for you, would you stick with the Avons? I'm running a 49/46 combo on mine, but would change for a noticeable bump in rear tire mileage. I'm pretty curious to see if you get better numbers with the M3s than with the Avons. Bryan...we don't get much rain east of the Divide...
This is exactly how I installed my DualStars (and my wife's on her Ducati 900SS): worked like a charm, and took about 1 hour to do start to finish (if you've got all yer crap handy). Bryan...lot cheaper than Aerostich, too...
