blackhawkxx
  1. I read a review on them a couple of months ago in Motorcyclist magazine and they really liked them. They look like a great dry weather tire but without using them, who knows. They may be like the Avons, some people love them (get a million miles on them) and others get no mileage, the front of the bikes shakes and they hate them.
  2. Did anyone find the answer to this? Are the Attacks good tires? Here is a link that I found:
  3. Thanks. I have read many different ways but I'm not sure which is best.
  4. What is the best way to bed in new front brake pads on a car or light truck in your opinion?
  5. I just heard that lately but I have been using brake cleaner on car rotors for about 30 years with no ill affect, so.............
  6. My son had a real simple 36 hp dry set-up on his 600 F4-I. He cut out part of his rear fender (above and forward of the tire a little) for the bottle, had a switch to use the horn button, put it on the dyno to make a map for the P.C. that he could switch back and forth for the street with his lap top. The thing would fly but the downside was the during the race, as the pressure and temp changed, so did his ET. It is hard to win races that way.
  7. Side the bike down the fork tubes.
  8. Rich at a idle isn't good for anything IMHO.
  9. Except for the first time that I changed my oil, I don't think that I have every checked it. I always get it all back when I change it and it's a Honda.
  10. I made mine shorter using my stick welder a couple of years ago. Works great.
  11. That is why I had the factory bearings put in my longer link.
  12. SeaFoam is great. About a month ago, I stopped and got gas in my Wing a half of mile from my house. Within a couple of blocks, the bike felt like it was running on three cylinders. I almost couldn't get it home. When I did, I put in a half of can of SF and started it up and within five minutes, everything was fine. I always keep a can in the garage.
  13. You never put it on, did you?
  14. A Bird in the hand is worth two in the bush.
  15. What, you missed the group buy? Northman did it.
  16. Sorry. You have to go through the tests in the manual to find which one or replace them all.
  17. I have the BT-14's. I love them but don't look for mileage.
  18. blackhawkxx
    Spools
    Doesn't your Pit Bull have plastic on the lifting tabs? My (non pit bull does) and it never moves or slides when I work on it. Do you have the 6mm shim in the rear? That would make your swing arm at more of a angle.
  19. So what was the difference from the printed instructions?
  20. My Dyno-Jet kit really helped my97. Totality removed the flat spot. People say it makes the mpg worse, I never check it and don't care.
  21. blackhawkxx
    Gearing
    The point is that for $30 and very little work, he can find out.
  22. blackhawkxx
    Gearing
    Alot of people go with the 16 front. It's cheap and easy (like some people around here).
