long story. Went to changed oil. Cracked the oil pan at some point. Might have been when I went to loosen the drain bolt, which had set so tight I was practically tipping the motorcycle off the center stand to get it to come loose. Because in any rate, when I replaced the bolt I had a small leak (which might have been the cracked pan already) So I tightened the bolt a bit more in an attempt to stop the leak which I thought was coming from the plug and stripped the oil pan.
But I assumed it was the bolt not tight enough because of being stripped.
Went and got an oversize drain plug bolt and put that in. STILL leaked. That's when I looked under the pan and saw the crack.
So either I cracked the pan breaking loose the bolt in the first place, or the oversize plug split the pan. (I'm thinking it was getting the bolt loose in the first place.)
So I ordered a new pan, and you have to remove the headers to get the pan off/on.
NeXXt time pay a pro to do it for you. Fucking rookie. :roll:
j/k I hope it all "worked out" for you.
