Chester Posted January 4, 2004 Posted January 4, 2004 I've been looking for 1157 led bulbs. Thought these were pretty cool cause they come in different colors. http://www.signaldynamics.com/products/bulbs/1157.asp Quote
birdie_xx Posted January 5, 2004 Posted January 5, 2004 You have the '02 XX, right ? The 1157 is a wrong bulb for your bike !!! From '99 on the bike takes all glass bulbs, 7440 or 7443 in the auto parts store.... This is true when we are talking brake/tail light bulbs :!: Cheers, Quote
Chester Posted January 5, 2004 Author Posted January 5, 2004 Ever since I put the clear fronts on, I'v been looking for a led front bulb. Those are the 1157.These seem to be a BIT pricey, but it is exactly what I'm looking for. For the rear, I have the clear lens with the single 2 or 3 inch led in it. Quote
Suf Daddy Posted January 5, 2004 Posted January 5, 2004 LED bulbs $15.00 to 9.99. Of course If I get ripped off even the $15 was too much.............. -Suf Daddy http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2452002345 Quote
TOXXIC Posted January 6, 2004 Posted January 6, 2004 Chad those, (in amber), would be sweet behind the clear front lenses! Quote
CBRXX Posted January 6, 2004 Posted January 6, 2004 I'm not sure they would work too good in the front lens. If I recall, the front bulbs are more sideways in the housing. You only really see the LED light when looking straight into those LED's. You can hardly see them from an angle. STeve Quote
Northman Posted January 7, 2004 Posted January 7, 2004 That's why there's a reflector in there.............. :wink: I'm sure they would light up bright enough. What about flash rates with these installed? Quote
r3ckl3ss Posted January 7, 2004 Posted January 7, 2004 you would need to change out the flasher relay or add some "load equalizers" in parallel... just resistors w/ heat sinks on them... otherwise you're gonna get the fast flashing syndrome... earlier it was mentioned about all glass bulbs... my 2003 has 1157s in the front and 1156s in the back. well, it did before i put the short stalks in... John Quote
birdie_xx Posted January 7, 2004 Posted January 7, 2004 Yep, Chester didn't specify he was talking turnsignals.... I meant the tail/brakelight !!! Miscommunication.... :roll: Cheers, Quote
CBRXX Posted January 7, 2004 Posted January 7, 2004 That's why there's a reflector in there.............. :wink: Wise ass! :grin: I was thinking more of the intended "look" of having the LED's facing forward, which they won't. They are probably a 45deg. angle to the front of the bike. If you look at the front lens, the bulb points toward the area where the lens and reflector meet. So, I think they might not actually reflect too much (off of the reflector) either. Those LED's seem to have a very directional light pattern. They look nice when viewed straight on, but show very little light from the side. Steve Quote
r3ckl3ss Posted January 7, 2004 Posted January 7, 2004 I've seen the LEDs w/ a 90 degree base... if someone was REAL motivated, they could buy the led and custom make a base with a 45 degree bend... how cheap were these things? r3ckl3ss Quote
