Is there any way to up the horsepower of a small 125cc scooter... ie punch the stock exhaust "blackbird style?"
air filter swap or drill out... ??
Any help would be great...
I have seen a few small engines that the factory uses different sized carbs on them to change the horse power output.
When I worked in the Marine business ,that was the case on a few of the Evinrude and Mercury outboard motors. Seen it on lawn equipment as well.
Check out the next model up, maybe a simple carb swap will next you a horse or two ... :icon_think:
2 stroke?
If so, there are companies out there that make custom expansion chambers specifically tuned to increas power at different rev ranges.
That's where I would start.
pete , there isn't a way known to man that will get that poor scooter over 25mph with you on it......I think I saw some where 7lbs equals 1hp, at that rate it has negative hp......
NBL
What kind of scooter is it? There is TONS of hotrod stuff out there for 2 stroke scooters. Big bore kits, bigger carbs, high comp. heads, you name it. Just Google the model of the scoot plus "performance parts".
Search: "Titanium wheel chair + performance parts"
:icon_biggrin:
NBL
That is not exactly true Mack. He could bolt a XX motor on it. :icon_lol:
NBL
Hey !!!!!!!!
we could do a Radar O'Reily..............we each mail a part of the bird to him.....................
