Try here:http://www.hdlparts.com/fiche_section_detail.asp
Which is hondadirectline.com for 1999-03, it shows a total of 7 friction disc (it seems to be 2 of one kind and 5 of another) and 6 plates. The clutches for 97-98 are different. I have not used Honda direct.
Honda Directline is about 4 blocks away from where i work. Also I am friends with the owner. If I can be of any help let me know. Or give Directline a call at 1-888-258-6699 and ask to speak with Drew. Drew is a good friend and is very knowledgable with the fiche / part numbers.
The shop manual says there's 7 disks and 6 plates.
The Ron Ayers fiche say's there 2 plates and 4 disks(2 of each kind)
What that hell?
I work for a Honda dealer and have access to the correct fiche. Let me know if I can help.
I must not be reading it right, that link still shows 3 plates and 4 disks :icon_think:
What that hell?
Sorry I'm a little late on this one.
The fiche is just an artists representation. Repetitive items aren't pictured, so you can't use it as a definitive guide. For instance, only one clutch spring is depicted.......you know there's six.
Why in the world do you need to replace all your disks and plates??? :icon_think:
What that hell?
My springs are at their service limit, so being the paranoid bastard I am, replaced the plates & disks since they had some wear too. It's been feeling a little lazy and I don't take chances on my trip Across the country :icon_lol:
How many miles on it, for crying out loud?
I've never had to replace a clutch.
50,000. It doesn't need replaced, just preventative+piece of mind+felt like the springs were loosing thier bite. I shift waaaaay to much I guess.
+1
I'm still using the stock clutch, with the exception of some HD springs on my big bore, and NO issues at all. Even abused at the strip a few times now.
Also, I asked on this site if I should bother checking the tolerances and just about everyone said if you are going to check it out, you might as well replace everything. So I did. :icon_lol:
Thread title "should I even bother?"
I checked the thread, and I read it as 3 to 2 against doing anything with the clutch.
No matter, its your decision, and certainly not a bad one. Its never a bad decision to replace components that normally wear. Unnecessary, perhaps, but not bad. Make sure you pull your clutch rod completely out and clean it.
