jimmystartup Posted October 24, 2005 Posted October 24, 2005 Yesterday I went on a nice 350 mile ride and noticed that my bike seems to 'waver' back and forth when riding at speed. Nothing too dramatic...almost imperceptible but certainly new. The bars feel like they move about a quarter inch each directing in, what I can only describe as a 'waggling' fashion. I recntly had new tires installed but everything is torqued and in place. The tires are Sportec M1s. Someone suggested my steering head bearings might be the culprit but they were replaced once already. I'm open to checking them. Any thoughts? :? Quote
CalamariKid Posted October 24, 2005 Posted October 24, 2005 Not sure that the steering head bearing would cause it to waiver, but you may want to check the balance of the tire. I would also check the wheel bearing and spacer to make sure everything got put back together right when they changed the tire. And make sure the tire is rotating the right direction (not put on backwards). Good luck, and if you don't mind post up what you find. Quote
redxxrdr Posted October 24, 2005 Posted October 24, 2005 I would also check rear tire alignment. I am now using a version of the laser tool wheel alignment jig. Shows that my alignment marks were not very accurate. But the chain now runs straight down the rear sprocket. Quote
JuXXtin Posted October 24, 2005 Posted October 24, 2005 You don't have a Givi Wingrack and/or trunk on by chance do you? That would/could cause it. Quote
K9XX Posted October 25, 2005 Posted October 25, 2005 I would have the front tire rebalanced. Easiest, fastest and cheapest fix to start with :wink: Quote
jimmystartup Posted October 25, 2005 Author Posted October 25, 2005 You don't have a Givi Wingrack and/or trunk on by chance do you? That would/could cause it. Nope. I was standing beside the technician when he mounted and balanced the tire so I know it was done right. Can the weight slip? Quote
K9XX Posted October 25, 2005 Posted October 25, 2005 I don't balance my tires with weights. I use Ride-On only for the past year. No gripes, just nice, evenly balanced tires When I remount, there is no mess, a paper towel wipes it all off the rim. http://www.ride-on.com/motorcycle.htm Plus I picked up a nail in the rear a couple tires ago. Pulled the nail, no air came out, instant plug! I love this stuff :twisted: Quote
dissolvedego Posted October 25, 2005 Posted October 25, 2005 I don't balance my tires with weights. I use Ride-On only for the past year. No gripes, just nice, evenly balanced tires When I remount, there is no mess, a paper towel wipes it all off the rim. http://www.ride-on.com/motorcycle.htm Plus I picked up a nail in the rear a couple tires ago. Pulled the nail, no air came out, instant plug! I love this stuff :twisted: wow, it's really that effective? no downside? i will have to check it out. Quote
99Birdman Posted October 25, 2005 Posted October 25, 2005 I don't balance my tires with weights. I use Ride-On only for the past year. No gripes, just nice, evenly balanced tires When I remount, there is no mess, a paper towel wipes it all off the rim. Their site doesn't indicate it can be used as a dynamic balancer. Do you just install the right amount and drive a few miles? Quote
K9XX Posted October 25, 2005 Posted October 25, 2005 wow, it's really that effective? no downside? i will have to check it out. Yes, it is. I have had the Bird topped out, with no wobble at all :wink: The ads are true, vibrations are absorbed by this stuff too! I now use it in my dirtbikes, and have yet to get a flat. I am considering buying the big jug for my truck, just haven't done it yet. Cheap insurance. I stopped carrying my plug kit on the Bird as well, unless I am riding with others, it nice to have for them Quote
K9XX Posted October 25, 2005 Posted October 25, 2005 Their site doesn't indicate it can be used as a dynamic balancer. Do you just install the right amount and drive a few miles? Taken from the above link: The product manufactured by our competitor was originally designed for use in bicycle tires, and according to their website is “not intended for speeds in excess of 75 mph”. Ride-On is designed to actually help hydrodynamically balance tires at highway speeds. Once installed in a tire, it will actually act to dampen vibrations for the life of a tire so you do not need periodic rebalancing. Although we don’t condone speeding, our dealers and customers comment that their bikes actually run smoother at speeds as high as 150 mph. I put a bottle in and go for a ride. In about 2 miles, everything is nice and smooth 8) Quote
99Birdman Posted October 25, 2005 Posted October 25, 2005 Taken from the above link:The product manufactured by our competitor was originally designed for use in bicycle tires, and according to their website is “not intended for speeds in excess of 75 mph”. Ride-On is designed to actually help hydrodynamically balance tires at highway speeds. Once installed in a tire, it will actually act to dampen vibrations for the life of a tire so you do not need periodic rebalancing. Although we don’t condone speeding, our dealers and customers comment that their bikes actually run smoother at speeds as high as 150 mph. I put a bottle in and go for a ride. In about 2 miles, everything is nice and smooth 8) Oops, missed that --- Thanks :oops: Quote
speedygeezer Posted October 25, 2005 Posted October 25, 2005 Did your bike wander before you replaced the tires? 1/4" movement is a ton of variation.....???? At what speed does this wandering begin? Any difference during de-celeration? Do the bars waver in corners, too? Did you inspect to see that the beads are seated properly all the way around on both sides of both tires? Quote
redxxrdr Posted October 25, 2005 Posted October 25, 2005 I would check the tires for tracking. Geoff used his laser on his alignment tool pointed at the edge of the tire. Split the beam with the tire, then turn the tire to make sure it tracks the same all the way around. If not, check the seating of the tire. Check both side, front and rear tires. I have also read where the front axle was installed with the pinch bolts a little too tight. The author said this caused the axle to seat wrong, and the forks to not be aligned. Might be worth loosening the pinch bolts, and re-torquing both axles. http://www.bikersoracle.com/jaws/waligntool.htm Quote
azxx Posted October 26, 2005 Posted October 26, 2005 Tire pressure, rear wheel alignment, uneven tread wear worn center. Quote
Obby Posted October 26, 2005 Posted October 26, 2005 Tire pressure, rear wheel alignment, uneven tread wear worn center. I had the same problem until I added some air to my front tire. I'm running it at 40lbs. now, no more wandering front end. Quote
XXLust Posted October 27, 2005 Posted October 27, 2005 Check that your steering head bearings are not too tight. Also check that nothing is interferring with steering movement. I had this same problem on an ST-1100 after replacing the steering head bearings...too tight. Miss-matched or one new and one well worn tires may also cause this. Let us know what fixes it. Gregg Quote
brianmacza Posted October 27, 2005 Posted October 27, 2005 WHat size back tire did you put on? Have you put a shim on your rear suspension? It almost sounds like the back has been raised too far and the steering head angle is making it too twitchy - this could come from having a 190 on the back and a 6mm shim.... Quote
jimmystartup Posted October 28, 2005 Author Posted October 28, 2005 WHat size back tire did you put on? Have you put a shim on your rear suspension?It almost sounds like the back has been raised too far and the steering head angle is making it too twitchy - this could come from having a 190 on the back and a 6mm shim.... I've got the stock 180/55/17 on the rear. I've installed the Wilbers shock but haven't yet installed the springs. Therefore, I haven't taken the time to carefully set my sag. You might be onto something there...and I never noticed it with the Conti's. Quote
demon Posted October 28, 2005 Posted October 28, 2005 A 190/50 is shorter and fatter than a 180/55, so that won't have anything to do with it. Is the Wilbers shock longer than stock? I've got the longer Wilbers and have raised it some more and mine doesn't wander at all. I don't think that the sag setting would have anything to do with it wandering unless it's way too tight and doesn't compress when you're on the bike. Mine was sent to me with too much sag in it and I had to tighten up the spring some. I'd about bet on steering head bearings. Quote
2equis Posted October 28, 2005 Posted October 28, 2005 Why is my bike 'wavering' Maybe it's French :roll: Quote
