What'up guys , can someone tell me if there are better set up clutch than the stock ones , for drag use . I'm doing some little upgrades to my 99 bird, I ride her hard on the street and visit the drag strip a few times a month, since you guys have more expirience than I (I'm just starting) and over here the xx is like something frome mars, people don't now how to make her run harder without lots of mods.
As of now I'm making the busas shake a little
since I'm asking, if someone throws in some sites that I could find some parts for drag aplications be realy thankfull.
BURN RUBBER NOT YOURE ASS!!!!!!!!!!!!!!!!!!!!!!!!!
I can't really help you with that one, even with my extensive track passes. I'm still on the stock clutch, and have no reason to change it. Mine even held up under the nitrous, slick, and wheelie bars, so I figure I better leave well enough alone. There's supposed to be a site that tells you how to rearrange the clutches to help with grabbing.
The problem with the stock clutch is not the strenght but how bad it grabs at higher rpm's. You just can't slide it like a cable clutch.
thats very correct blackhawk ,I'm having all kind of problems with my way out of the lights
5k slip the clutch and booom one wheel all the way it realy suks
furbird do you now the site ,maibe I coud find a way to make the clutches to slip a little
I lost it sometime when I change internet providers. Sorry.
I've always found on my bike that if you slip the clutch out just before the tree comes down, it kinda "spins up" the clutches and basket and makes them not grab so hard when you come out of the hole. You like "drag" the clutch a little and pull it in real quick a couple of times before you stage. I can slide mine just fine by doing that. The initial clunk scared the shit out of me the first time it happened to, and this redneck idea solved the problem. The clunk happens when you drag the clutch out the first time, then when you launch it doesn't do that.
thanks furbird I'll trie that the next time out and see what happens
the thing is that have to fight with her when I go out and thats killing me on the first 60.
another thing is that I'm a big m.f and I'm runing on 16/45 and I don't slip the rear, she comes up like a rocket
lets see what I can do with that .
Have you tried strapping the front? They are only about $25 and I leave mine on all the time, just keep it loose. It really helps with the front end.
been there, don that
That helped a little but still not mutch
and she's drop 2 inches in the front and about 1 3/4 on the back
every thing els is stock on the suspention I meen.
I.m tring to leave the back end stock as muych as I can
but I now some time soon I'm going to have to pull her back
EFR sells a cable clutch conversion. And I think that would help alot ! Elton said "that is the best upgrade for drag racing a XX...."
http://www.efrracing.com/
I spoke with Elton about the clutch conversion and a lockup clutch a couple years ago, and a turbo if you really want to know. By far the best bang for the buck is the cable conversion for launching the bird. The stock clutch will handle the power until you start adding big shots of nitrous or a turbo.
Need to correct the nitrous statement. I run probably the biggest shot on here, and while I haven't sprayed it much, it has held every time that I have. I'm not suggesting it will hold it forever, but it will hold a big shot of gas without slipping. So will Contiforce tires.
...with enough weight on the seat like I provide anyway :lol:
