Goobr Posted February 2, 2005 Posted February 2, 2005 I just won them off Ebay. 53 bucks. :headbang: Any "watch-outs" or tips I need to know about installing them? I've read that brake lines and cables need to be a bit longer,,,, that filing down the tab on the brake reservoir will work at repositioning the stock brake lines. Anything else besides "just doin' it"? TIA Quote
RichardCranium Posted February 2, 2005 Posted February 2, 2005 When installing the bars be very careful not to drop one on your toe. This goes double if you are wearing sandals. I suspect it would hurt. :grin: Quote
Guest rockmeupto125 Posted February 2, 2005 Posted February 2, 2005 The first thing to do is to see if they fit. Just because they are from a VFR800 does not automatically mean that. They need to be from a 2002 or newer. Quote
Goobr Posted February 2, 2005 Author Posted February 2, 2005 Right,,,, 2002 they are. I made sure of that. I looked at a couple of parts fiches, fishes, fishys, fishies?,,,,,,, the difference is a helluva lot. Soooo, with that said, I reckon I'd better go to Wally World and buy some shoes. I AM from Georgia ya know. :fingerflip: Quote
Red J Posted February 3, 2005 Posted February 3, 2005 Send them my way, I'll install them for you. :grin: J. Quote
Goobr Posted February 3, 2005 Author Posted February 3, 2005 Send them my way, I'll install them for you.:grin: J. Too late, already done went and bought muh shoes. Quote
wr0ngway Posted February 3, 2005 Posted February 3, 2005 They don't fit. Throw them away and buy my Heli-Bars. $220 or send me $100 plus the VFR bars. - 10% geckobox discount Congrats on a good deal. Quote
Helvet Posted February 3, 2005 Posted February 3, 2005 Dont forget to change your gascable. You need to divert it on the other side of the fork (outside instead of inside), and take the cable from the notch under the gastank. If you don't do this, your bike will suddenly speed up in very tight left turns. This can be quite a surprise...... Also please check this posting: http://bb.superblackbird.info/viewtopic.php?t=95 Quote
Pete in PA Posted February 4, 2005 Posted February 4, 2005 I disagree with the throttle cable routing. It will be fine running throught the forks, the standard location. I have mine uncliped from the frame though also. Btw great price on the bars on Ebay. When I was trying te get mine I bid on several that kept going up to around the price for new. :roll: Then I got some for $75 privately, no Ebay. I never even thought of switching right for left, has anybody here done that? It should work for stock bars. I bought my bike used with helibars already on, so I couldn't even try it though. Quote
UncleJake Posted February 4, 2005 Posted February 4, 2005 I tried to swap the stock bars right to left, but the riser portion of the stock bars interferes with the brake/clutch reseviors. :???: You would also have to postion them straight out to avoid the tank. It may be different with VFR bars though. -UJ Quote
Pete in PA Posted February 5, 2005 Posted February 5, 2005 You'll lose out with doing that with the VFR bars. The left right thing was just for the stock bars. Too bad it doesn't work. It looked good. Quote
robert Posted July 4, 2005 Posted July 4, 2005 So how much better is it with the VFR bars? How much weight will it take off my shoulders and wrists? I was riding 1800 km in the last 3 days with passenger and that made me even think to sell my bird and get a FJR. Quote
chaserkeywest Posted July 5, 2005 Posted July 5, 2005 Convertibars www.convertibars.com Up 3 inches, back 2 inches. You will/may have to shave your screen. You will have to do a clutch/Brake hose extend. You can drop them down for Knee draggin in 3 mins You will be very comfortable Chaser Quote
stewmg Posted July 5, 2005 Posted July 5, 2005 Great price. Easy mod, just loosen the lines to the brake and clutch resevoirs slightly, should be able to move them to their new position without loosing any fluid. Might not hurt to put a cloth under them just in case. Take the throttle line out of the clip, no need to move it. Cut the clips off the resevoirs. I raised mine on the fork tubes just enough to clear the tabs (about 5/8 of an inch) and pulled them back so they just cleared the tank when right at the stops. Feels great with the extra height. Good luck. Quote
Keith Posted July 5, 2005 Posted July 5, 2005 They won't work on your bike; just sell them to me for the same $53 including shipping, I'll be happy to take them off your hands. J/K They should work fine on your bike; no problems. Quote
