Squareman357 Posted July 9, 2006 Share Posted July 9, 2006 Was helping/watching one of my cousins friends change the oil in his GSXR. He forgot lefty loosy, righty tighty and stripped the oil drain bolt hole threads. He was considering his options (we got it tight enough for him to slow ride home, which was only a few miles of local steets) and I thought about Helicoil. Is this a recommended option? If so, where does he purchase one and what do you have to do to install it? Quote Link to comment Share on other sites More sharing options...
Motor Psycho Posted July 9, 2006 Share Posted July 9, 2006 http://www.mcmaster.com/ Some of the larger hardware stores have Heli coil kits, but McMaster Carr is your best bet for larger metric sizes. You can buy a kit that will have everything you need with instructions. Another option I've seen done before is to simply tap out the hole to the next largest pipe thread. Pipe thread is tapered, and taps and plugs would be available at most hardware stores. Quote Link to comment Share on other sites More sharing options...
jrdxx Posted July 9, 2006 Share Posted July 9, 2006 Check your local auto parts store (AutoZone, or whatever). The one local to me actually has a pretty comprehensive set of Helicoils, including metric sizes. Quote Link to comment Share on other sites More sharing options...
tomek Posted July 9, 2006 Share Posted July 9, 2006 The other option is "oversized" bolt.It is aftermarket solution to stripped oil pan treads.Years ago I stripped one on my FJ1200.The replacement worked like a dream. It basically has a taper on the end and couple slots to cut slightly oversized treads.I guess in order for that to work there has to be some tread left to guide oversize one in.It costs 3-4 bucks,and it is lot less work then heli coil.You need to know the size of O.E.M. bolt ( like M14X 1.25) to pick up correct one. Or take the O.E.M. with you,should be able to figure out the tread by comparision. You can find them in auto parts stores,pep boys,murphie`s (sp?),etc. Quote Link to comment Share on other sites More sharing options...
ccriderXX Posted July 10, 2006 Share Posted July 10, 2006 I saw heli-coils locally at Tacoma Screw Products. No really.. http://www.tacomascrew.com/ Quote Link to comment Share on other sites More sharing options...
