Seems like the price point is around $600 minimum for a bi-directional tool that works with OBD and CB based systems. A regular TPMS tool looks like $150-$200 on Amazon, not sure how they are selling them for $75 on FB.
I was looking for something that would program multiple makes. Regarding TPMS, tutorials are very vague and black art-ish. Apparently there's programming, relearning, cloning, and all on different platforms. I just want to be able to find and replace the non-working one without spending an entire afternoon inflating and deflating trying to logic the problem to death. I also would like to switch to my winter rims without spending time at the garage and paying for that service. Granted, I could put a piece of tape over it, but it is a useful tool, why not utilize it.
Do any of our weekend garage monkeys use a TPMS reprogramming tool? Looking for one myself, cuz I have too many vehicles and they most all have monitors with failing batteries.
VFR Swingarms SOLD
rockmeupto125 replied to rockmeupto125's topic in The Sales Floor -- For Sale/Wanted
I am no longer the guardian of these items. Care had been assumed by someone who is by far much crazier than myself. -
I don't think they did numbers, SAE, metric, or whitworth. Probably rule of thumb.
So as part of the whole mess, the load bearing walls are on 2ft centers, as are the trusses in order to maximize the load bearing capability of the roof. However, the non English speaking crew that erected the structure apparently didn't do numbers either, so some of the open areas are 28 inches, some are 22, and that means that each piece of insulation has to be cut individually to fit where it's gonna go.
VFR Swingarms SOLD
It was fun project idea, but time is shortening, and the project has lost priority with me. Part of retiring is shedding myself of things that no longer matter, like in your rear view mirror. -
Maybe, but might take a lot, multiple coats over the dark surface and not sure how absorbent it is. Several good points. I do question that you get 1 inch polyiso foil faced insulation for 13 dollars. The link you posted is r2.9, the 1 inch poly is r5.8. it would cost me about $1200 for that new insulation to cover 1600 sq ft. I'm about to set it all on fire. Oh wait...it won't burn.
They do make foamboard with foil radiant facing. I paid $7.50/4x8 of non-foil faced, and I'll have to cover it myself. I found 5 gallon pails of generic liquid nails for $80, which would probably work well to adhere the sheeting. I'd just have to split it into smaller containers so it doesn't set up while I'm working. I'd rather something a bit less viscous, but that's the cheapest I've found yet other than wallpaper adhesive, which is basically starch.
So many projects that I will never have time for and the fire has waned. I have two early 90's VFR swingarms free to board member paying shipping for one or both. I thought an SSA conversion would be fun too do. It would, I don't have the time. Maybe you do, and if so, here's a good start.
Which one are you referencing?
It's been a while, but as I recall, you have to unbolt the subframe to jimmy the plug through. Or, you can take a pick and unloose the connectors from the plug, feed them through, and snap them back into the connectors.
I want to bond sheet plastic as a radiant barrier to Glass Reinforced Fiber (GRF) facing on polyiso insulation. Both are pretty inert. I wonder if wallpaper adhesive would work. That's like $90/5 gal. I did find some subfloor adhesive for $80 as well.
Looking for a cheap solution. I am looking for a relatively inexpensive adhesive (I'm thinking maybe 5 gallon bucket) that I can apply with a brush. I want to adhere thin (8 mil) plastic sheet to a fibrous backing, kinda like a pressed cardboard. Small pieces up to 4'x8' pieces. There's no mechanical stress to the bond, no significant moisture component or exposure to the elements, and there's mechanical fasteners as well. I really would just like a small amount of adhesive to keep the plastic flatter to the board. Any suggestions? It's hard to google something this specific, especially with the poor performance of real results from the search engine. Thanks!
Couple of Ram phone holders
rockmeupto125 replied to SwampNut's topic in The Sales Floor -- For Sale/Wanted
Do my best. -
Do you want to ship them or carry them? Either way, I'll take 'em. Got lots of bikes. -
*SOLD* 1997 CBR1100XX Blackbird for sale
rockmeupto125 replied to Chewtoy's topic in The Sales Floor -- For Sale/Wanted
So glad I am quite a far way from this. -
Anyone near Beverly Hills?
rockmeupto125 replied to XXitanium's topic in The Sales Floor -- For Sale/Wanted
I guess it would be a comical SNL skit, but no. -
Windows 10 mini PC free to good home
I think this would be good for the garage and I have a monitor I'm replacing that would go well with it. I'll speak for it, but will defer to someone who needs it rather than just can use it. -
2002 Rally Prepped CBR1100XX $3500
rockmeupto125 replied to danstephans2's topic in The Sales Floor -- For Sale/Wanted
That's nice. 10-15 years ago I would have been all over that. Good luck with sale. -
Does the bolt go all the way through to the inner wall of the silencer? I'm just leery of using chemicals on chinesium exhaust. That just seems like high risk for tearing the tack welded nut off and not being able to remove the silencer.
I'm just getting the idea that this fix should mechanical, not chemical. Between the constant vibration and high heat, I agree with the idea of safety wire, or a large headed bolt that a spring clip large enough not to be able to turn in the muffler body... But you would have to safety wire the clip. How about earplugs?
