DerekJaworski Posted December 25, 2016 Share Posted December 25, 2016 The petcock was cut out and replaced by a previous owner on my 98 bird, so I'm not positive that it OR even the tank belong to this bike. Does anyone know if this is the right one and/or know the on/off/res positions? Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted December 25, 2016 Share Posted December 25, 2016 If nobody can ID it for you you'll have to pull it off and see if it has two inlets and which one flows in what position, blow through them while turning the valve, or add some gas to test which position does what. It appears to have a P on the left which would be the prime position, allows flow with the engine off and no vacuum signal. If it's not a vacuum controlled valve then that's likely an R and should answer your question. Quote Link to comment Share on other sites More sharing options...
redxxrdr Posted December 25, 2016 Share Posted December 25, 2016 Old thread with petcock pictures Mine is FI, hope this helps Quote Link to comment Share on other sites More sharing options...
