blackhawkxx Posted March 21, 2004 Share Posted March 21, 2004 Some people think that changing a rear tire on a Bird is a pain. You should try it on a Goldwing. Here is what I am doing. Quote Link to comment Share on other sites More sharing options...
blkbrdrydr Posted March 21, 2004 Share Posted March 21, 2004 I've found that it's easier to remove the entire rear section than to remove the saddlebags and the rear fender. HOWEVER... I've screwed with those rear tires enough to learn that it's far easier to leave the job of removing that rear tire to someone with the correct lift that allows removing it without having to remove any of the plastic. Thankfully, the rear tires can last close to 25,000 miles and don't need to be changed too often. :grin: Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted March 22, 2004 Author Share Posted March 22, 2004 it's far easier to leave the job of removing that rear tire to someone with the correct lift that allows removing it without having to remove any of the plastic. What do you charge you for something like that? Quote Link to comment Share on other sites More sharing options...
