TurboJoe Posted March 16, 2014 Share Posted March 16, 2014 Well I finally did it!!! ZX front end is installed. Thanks Stan, iFanboi and others that chimed in and answered my many questions. I knew exactly what to expect. Test fit went well... Pics attached Quote Link to comment Share on other sites More sharing options...
IcePrick Posted March 16, 2014 Share Posted March 16, 2014 Damn, that came out clean looking! What did you do/plan on doing for steering stops? How did the run for the brake line go? I'm not happy with either of those on mine so far. Quote Link to comment Share on other sites More sharing options...
TurboJoe Posted March 17, 2014 Author Share Posted March 17, 2014 Well....the stops will be revisited but basically using Allen's will plastic spacers for now. It appears to be enough room to have a piece made to attach to the frame to bump the lower triple. Allen's work for now. I am working on the brakes soon. Don't have lines yet. What can I expect there??? Turn radius is drastically reduced but that will mostly be an issue in parking...do you have this problem??? Quote Link to comment Share on other sites More sharing options...
IcePrick Posted March 17, 2014 Share Posted March 17, 2014 Yes, the turn radius is reduced, but not a huge issue. I still have the stock brake lines, and there is no good way to run them without them interfering with the forks. The ideal would be to have braided stainless lines and route them appropriately, I've just been lazy, that might be a project to get done before the nice riding weather is back. Quote Link to comment Share on other sites More sharing options...
cbrxxquad Posted March 18, 2014 Share Posted March 18, 2014 http://www.spieglerusa.com/ lines due to the fact the ends turn. Hate all lines that are not. They never go the way I want them to otherwise. Quote Link to comment Share on other sites More sharing options...
TurboJoe Posted March 18, 2014 Author Share Posted March 18, 2014 Thanks Stan...That was very helpful. Quote Link to comment Share on other sites More sharing options...
TurboJoe Posted March 21, 2014 Author Share Posted March 21, 2014 Finished taking care of the fork/ram-air tube clearance issues (SP1 lower issue that Stan spoke of) and got my steering lock to work...WooHoo!!! I measured for braided lines made. Puig dark smoke DB windscreen looks really trick (a lot better than the el'cheapo screen that was on it when I got it). I still have a few weeks to wait on the swingarm to be built and shipped but I am sooooooo happy that the front is nearly complete. Riding season is upon us :-) Quote Link to comment Share on other sites More sharing options...
TurboJoe Posted May 5, 2014 Author Share Posted May 5, 2014 OK All....Introducing.......Dos Equis. And to everyone that replied to my post while I worked my way through the ZXXX build, I want to say "Thanks Guys". Your help saved me some costly experiences. Quote Link to comment Share on other sites More sharing options...
cbrxxquad Posted May 5, 2014 Share Posted May 5, 2014 Verrrrry nice! Hows it ride? Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted May 5, 2014 Share Posted May 5, 2014 Yea, give us the report. Quote Link to comment Share on other sites More sharing options...
IcePrick Posted May 5, 2014 Share Posted May 5, 2014 OK All....Introducing.......Dos Equis. And to everyone that replied to my post while I worked my way through the ZXXX build, I want to say "Thanks Guys". Your help saved me some costly experiences. Looks great! Please let me know where you set your triples - mm from the top of fork tube to top of upper tree. We either saved you some costly experiences, or we were the cause of it - either way, you're welcome! Quote Link to comment Share on other sites More sharing options...
TurboJoe Posted May 6, 2014 Author Share Posted May 6, 2014 Verrrrry nice! Hows it ride? Ride is excellent...I am very pleased. Stan maybe you can explain this...I used an F4i front brake master with 08 Hayabusa Tokico's with spacers (ZX14 Nissan were very pricey) and they work great. I was prepared to buy a radial master but I see no need. The F4i MC is slightly larger than the Busa's but everyone stated that it would be very soft. I am sure I got help from the braided hoses. I tried it for looks but functionality was the outcome as well. OK All....Introducing.......Dos Equis. And to everyone that replied to my post while I worked my way through the ZXXX build, I want to say "Thanks Guys". Your help saved me some costly experiences. Looks great! Please let me know where you set your triples - mm from the top of fork tube to top of upper tree. We either saved you some costly experiences, or we were the cause of it - either way, you're welcome! Out of town at the moment but will post the measurements when I get home this weekend. Yea, give us the report. A full report will be posted with pics soon Quote Link to comment Share on other sites More sharing options...
cbrxxquad Posted May 6, 2014 Share Posted May 6, 2014 Are those 6 piston? I would think as long as the master is larger it would be harder not softer. Long as it feels good and stops good. I pull as hard as I can on the lever....stopped of course...to make sure it has some movement after what it normally takes to stop...cushion... and does not go all the way to the bar. All good. Mike, I have changed my settings on the zxx trees. Back to the top. Not lowered. Went back to the xx swingarm too. Tall bike now. Not really, but really different than before. Got a idea from the TSR linkage I wanted to try. Did some research into progressive and linear triangles. Got an adjustable link too. Wanted a more neutral turn response. Something intuitive. Your going to have to try it. Oh yeah... and a 1000rr rear shock as delivered. Quote Link to comment Share on other sites More sharing options...
TurboJoe Posted May 6, 2014 Author Share Posted May 6, 2014 Are those 6 piston? I would think as long as the master is larger it would be harder not softer. Long as it feels good and stops good. I pull as hard as I can on the lever....stopped of course...to make sure it has some movement after what it normally takes to stop...cushion... and does not go all the way to the bar. All good. No they are 4 pots...i have plenty of cushion with a nice firm feel. Quote Link to comment Share on other sites More sharing options...
