NoOne65 Posted September 16, 2013 Share Posted September 16, 2013 So I am trying to tune the carbs of my 97 and while its idling I hear a clunk then gasoline mist out of number 3 cylinder as it dies. I crank it again and its idling for a few minutes then it does it again only this time it recovers and idles without the gas mist..I am afraid to do anything else for fear of putting a rod or something through the block. First thoughts? Cam chain tension? valves? 92K on the bike. I know what a rod knock sounds like it would seem if that was the problem I would hear it during idle. Two years of putting things back together and right when I think I am gonna be able to ride... If anyone has any ideas? J Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted September 16, 2013 Share Posted September 16, 2013 If its blowing gasoline mist out around the spark plug, I'd tighten the plug. Should we assume your mist is coming back out the carburator throat? Pull the plugs and take a look at how #3 looks compared to the others. Quote Link to comment Share on other sites More sharing options...
NoOne65 Posted September 17, 2013 Author Share Posted September 17, 2013 fresh plugs. I assumed a lean condition do i removed the bowls cleaned out the bowls and found gas was cloudy so after cleaning them got fresh gas, then synched them and seemed to idle fine but still have fan problems Quote Link to comment Share on other sites More sharing options...
slowrideCX Posted September 17, 2013 Share Posted September 17, 2013 I was gonna say it sounded lime a lean stumble. As far as the fan try jumping aroind the fan switch to see if the fan comes on. Quote Link to comment Share on other sites More sharing options...
NoOne65 Posted September 17, 2013 Author Share Posted September 17, 2013 Seems to be running fine with fresh fuel...and fan issue was a wasp nest blocking the fan rotation!! go figure! Thanks again! J Quote Link to comment Share on other sites More sharing options...
