kiwimack Posted July 20, 2013 Share Posted July 20, 2013 2003 bird Found the connector for the R/R melted. I had been noticing the voltage was off from last week. Wouldn't get to any more than 13.4 as opposed to regularly sitting at 14.4 last week. Hard wired the yellows am now getting 6.5 off each wire. Don't know what it is supposed to be. R/R Gone? Stator? I have an R1 R/R will just need to grind it down if I need to use it. Any ideas? O Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted July 21, 2013 Share Posted July 21, 2013 I know it's hard to tell now, but what was the quality of the connection before? I tried slathering on the dielectric grease for the R/R connector before I had to replace it. If it's dry/dirty, there's a lot of resistance there. My guess is once it starts getting hot, the connector starts to cook away. Now, if you have damage, I don't know. You can test the R/R and stator wires, but just because they test good now doesn't mean they won't go next week or next month (as it happened to me last year). Given the circumstances, if you replace the R/R, go ahead and replace the stator too...just in case. Quote Link to comment Share on other sites More sharing options...
EVLXX Posted July 21, 2013 Share Posted July 21, 2013 Check recent threads on this subject... Test Stator, via Hobie's thread... and methods. Replace parts... Cross fingers and hope it's all fixed. Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted July 21, 2013 Share Posted July 21, 2013 Check recent threads on this subject... Test Stator, via Hobie's thread... and methods. Replace parts... Cross fingers and hope it's all fixed. If you feel the need to replace either the R/R or the stator, DO BOTH. A stator on the edge of failure can test fine, but when it goes, it can toast a good R/R and vice-versa. Parts-wise, they aren't that expensive to replace. Get a good set from Ricks (IIRC). Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted July 21, 2013 Share Posted July 21, 2013 hobies writeup on the stator will help you. if you get an off number on your stator check then the enamel coating on the cooper wire has broken down and is shorted out. Quote Link to comment Share on other sites More sharing options...
